Removing Thin Set - Flooring - DIY Chatroom Home Improvement Forum
Old 11-20-2011, 10:24 AM   #1
Removing thin set
I've been using my Makita hammer drill ton remove thin set but I can't seem to make anymore progress.
We are putting in 12mm laminate flooring and have been told we need a well prepared floor.
Attached are three pictures of the current floor condition.
Any suggestions on how to proceed would be greatly appreciated.
Also what is the best way to level this concrete floor?
Tia,
Todd
Todd_C is offline   Reply With Quote
Old 11-20-2011, 10:36 AM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
The "close-up" pictures are really handy, now we can get into the molecular structure and make up of the subfloor.
Old 11-20-2011, 11:25 AM   #3
Do I sense sarcasm?
Lol sorry ill do that again
Todd
Old 11-20-2011, 11:29 AM   #4
Here are some closer pictures. And one with a bigger view
Old 11-20-2011, 11:37 AM   #5
Bud,
I am a complete moron when it comes to this stuff. So I'm very gullible and will easily misinterpret what to do. Just a heads up
Old 11-20-2011, 11:42 AM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Meaning...
A couple of photos with a landscape view would be more beneficial than a few super close-ups of who knows what.
OH...and YES...That was sarcasm.
Old 11-20-2011, 11:56 AM   #7
Meaning...
Ok landscape views.
This is the entrance hallway and kitchen which were stone floor.
I need a level floor for the new laminate flooring. It's not looking good at the moment and I'm running out of time.
Old 11-20-2011, 12:37 PM   #8
Tileguy
Bud Cline's Avatar
Rewards Points: 558
The floor (substrate) should be "flat/plane", not necessarily "level".
The best way to plane the floor is to use a floor grinder. A few pocks and divots won't be a major problem.
A floor grinder can be rented along with the necessary grinding stones. A chipping-hammer will probably do more damage.
The only other (more costly) method would be to use Self Leveling Compound and pour it on the entire floor.
If there are no major humps and bumps then the laminate may work out okay.
The pictures don't look that bad from here.
Thin set vs mesh porcelain floor tile over plywood subfloor and vinyl flooring Jerseygirl Tiling, ceramics, marble 49 05-23-2013 01:04 PM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
thin set removal from hardwood floor Dhays Flooring 1 10-26-2010 03:03 PM
removing thin set from back of tile Tralf Flooring 4 05-31-2009 11:25 AM
Removing Excess (dried) Thin Set wshouse Flooring 18 07-16-2008 11:38 PM
