-   -   removing subflooring (http://www.diychatroom.com/f5/removing-subflooring-125813/)
mollymaggie 12-06-2011 06:24 PM
how do i remove the top 1/2" subfloor from the bottom 3/4" subfloor that is glued and nailed with ringshanks?
Bud Cline 12-06-2011 06:27 PM
Gonna need more info.
titanoman 12-06-2011 08:32 PM
Don't understand your question at all. Slow down, check your spelling. Are you trying to remove 1/2" plywood that has been glued to 3/4" plywood? Impossible without destroying both layers. Why do you want to do this?
mollymaggie 12-06-2011 10:31 PM
subflooring removel
i am remodeling my kitchen/dinning room. The dinning room has 3/4 plywood, the kitchen has 3/4" plus 1/2" plywood. I have new 3/4" hardwood flooring for the area. Adding 3/4" flooring in kitchen area without taking out 1/2" plywood will make floor to high for dishwasher and compactor to fit.
Bud Cline 12-06-2011 11:43 PM
There ya go now see how easy that was.
You may have to remove everything down to the floor joists in this case. All you can do is get after it and see what happens. Plan on the worst in this case, anything less will be a reward.:)
