Removing Stuck Under Lay Foam HELP!! - Flooring - DIY Chatroom Home Improvement Forum
Old 11-22-2009, 07:04 PM   #1
Question
Removing stuck under lay foam HELP!!
Hi Everyone,
I am doing a DIY and putting in new Bamboo fiber flooring. Whom ever lived in my home before I bought it, saw it fit to use a old foam back carpet as underlay for their carpet. So now I have the task of trying to get the stuck foam under lay off the wood base. Does any one have ANY tips as to getting this stuff OFF. At the present Just doing the scraping. Hard work. Any and All hints would be helpful. Thanks Gang Sue
SusanM is offline   Reply With Quote
Old 11-22-2009, 07:13 PM   #2
DIY staff
Rewards Points: 7,174
Try Spraying it down with some warm soapy water--then scrape--Usually works for me--MIKE--
Old 11-22-2009, 08:20 PM   #3
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 182
Dull the blade a little. A new sharp blade will dig into the floor.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 11-22-2009, 10:14 PM   #4
Smile
Under lay stuck
Hi and thanks for the in put, I did figure out after trying a few different ways that if you use a belt sander with a rough grid paper, it stripes it away very fast. Heat gun was just way to smelly. So for any one in the future wants to get the job done faster with only a small bit of scraping. Sanding is the way to go. The Foam does not burn at all and does not turn it into a fine dust. So no breathing in of the foam pieces. This works great I think and I will not have sore arms from scraping. If I had a floor sander I thing that would be best. But for now it works. Sue
Drywall over 1-1.5" rigid foam? michael76 Drywall & Plaster 23 05-22-2011 03:07 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
fiberglass over rigid foam board in cantilever? KatieAK Building & Construction 3 11-17-2009 07:48 PM
closed cell vs open cell foam insulation amonalisa Building & Construction 1 11-06-2008 09:39 PM
Spray Foam/ Foam Board Hybrid? entropyracer Roofing/Siding 2 09-19-2008 07:12 PM
