Old 06-24-2012, 07:59 PM   #1
Removing stones from concrete floor
So im in the process of buying a new house. It is a two story brick home and the 1st floors is actually half way under the ground. They have tile on the entire floor but a portion of it has stones. In the same area they have stones on the wall. My guess is that the stones are there for fire purposes since there is an old wood burning stove. I want to get rid off all of the stones and tile and put hardwood down. How should I go about doing this? Any ideas would be greatfully appreciated. I have remodeled homes in the past but never came to this problem. I have always ripped tile off of duroc.
Thanks,
Dustin
dpayne is offline   Reply With Quote
Old 06-24-2012, 08:59 PM   #2
Super Moderator
You need to post a picture for a good answer--but I imagine that the stones are set in thinset,on top of the concrete---a hammer and chisel will knock those off.
An electric chipping hammer would be helpful if there are a lot to remove.
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 02:37 PM
no framing concrete slab bathroom floor needs to be repaired in one spot barrr Flooring 1 05-15-2012 10:01 PM
Floor Joists on Concrete loftezy Building & Construction 1 02-23-2011 05:09 PM
Small dip in concrete floor. kath81 Flooring 3 11-12-2010 05:32 PM
Removing mortor from a concrete floor Kirk71 Flooring 2 03-09-2009 10:06 AM
