Removing Staples From Plywood Underlayment - Flooring - DIY Chatroom Home Improvement Forum
Old 08-19-2009, 09:52 PM   #1
Question
Removing Staples from Plywood underlayment
Man, there's got to be a better way to do this than pulling one by one with pliers....It's thousands of them here and It will take me four full days!!!.....Can I beat them down? It's there a tool I can buy or rent? Do I need to smooth the 3/4" plywood with portland cement before I put down the ditra membrane with modified mortar?.....Any advise is greatly appreciated
fjlcisco21 is offline   Reply With Quote
Old 08-19-2009, 11:03 PM   #2
Rewards Points: 51
I'm with you. I was pulling them out with pliers too. I did find, however, that if you use a long-handled floor scraper, and scrape the plywood with it, it will actually pop quite a few of the staples out, or at least make them easier to remove with pliers.
Good luck
preciouschristy is offline   Reply With Quote
Old 08-20-2009, 01:04 AM   #3
Tileguy
JazMan's Avatar
Rewards Points: 232
No need to remove them, pound them into the subfloor. Only go back and remove the stubborn rascals that got bent while hammering.
Jaz
Old 08-20-2009, 08:07 AM   #4
Thanks to you both, precious and jazman....That makes me feel much better that I can just hammer them down....
Old 08-20-2009, 08:07 AM   #5
Licensed Engineer
Rewards Points: 171
Options..........
  1. Hammer
  2. Fence pliers
  3. Channel Lock pliers - grab then roll the staple out like with the fence pliers, easier than pulling
  4. Garden rake - pull towards you to yank the suckers out
  5. Silage fork (ensilage fork) - like a pitchfork but with many closely spaced tines
MI-Roger is online now   Reply With Quote
Old 08-20-2009, 08:11 AM   #6
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 14
I have always used a spud hoe. It will knock out or cut off most of them.
Old 08-20-2009, 10:44 AM   #7
Rewards Points: 4,454
we place 1/4" luan
Old 08-20-2009, 01:56 PM   #8
Military Mom of 4
Snav's Avatar
How's the hammering going? Some flooring permits it - some don't.
I found the easiest thing was to just use a demolition crowbar and a hammer. Stand over the staple, set the the crooked end of the crowbar against the staple and whack it with the hammer ... usually they pop right up.
Snav is offline   Reply With Quote
Old 08-22-2009, 11:37 AM   #9
That's my answer. We can clear a 12x12 room of tack strip & staples in about 15 minutes with a flat bar & a spud hoe.
pinwheel45 is offline   Reply With Quote
Old 04-07-2012, 08:21 PM   #10
removing staples
I am remodeling my bathroom and have searched the internet for a tool to remove staples. I tried everything!!!! Then my daughter and I went to home depot to look for some sort of took that would work better than pliers or a pry bar. My daughter found a cotter pin extractor, worked WONDERS!!! it's the best 7$ I ever spent.
Dawn85 is offline   Reply With Quote
Old 04-07-2012, 08:50 PM   #11
Rewards Points: 12,858
Louon is not a sutable underlayment for any type of flooring, except carpet, and I guess it would be ok for laimite.
It causes glue reliece, staining, and has voids in the plys.
And should never be used anyplace tile is going to be installed.
Old 04-07-2012, 08:53 PM   #12
Rewards Points: 14
Originally Posted by itsreallyconc View Post
we place 1/4" luan
Like Joe said, never ever use luan.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
plywood underlayment installation interplexr Building & Construction 1 02-08-2009 09:45 AM
Removing tile from plywood underlayment Martinglmt Flooring 3 12-13-2008 08:06 PM
Sheet Vinyl....plywood underlayment or luan? AllGoNoShow Flooring 3 05-28-2008 06:57 PM
Removing kitchen tile with plywood under it ediconu Flooring 4 08-26-2007 09:48 PM
Backer board vs. plywood for tile underlayment allpraisebob Flooring 4 01-07-2007 08:44 PM
