Old 07-02-2008, 07:53 PM   #1
Default Removing stains in hardwood flooring
Hello. I am trying to refinish a section of my hardwood floor. There is a particular problem area where the wood is stained/dirty/discolored after the sand. The bare wood has become dirtier due to being exposed to traffic while waiting for me to figure out a solution before applying the finish. Does anyone have any suggestions for a good cleaner that can be used safely on bare wood?
Max1119 is offline   Reply With Quote
Old 07-03-2008, 12:17 AM   #2
1. mineral spirits
2. bleach
The mineral spirits will evaporate from the wood completely without leaving a residue. The bleach will have to be cleaned off with water. Both bleach and water will raise the grain of the wood.
If the discolouration of the wood is blue or black and was caused by watering potted plants that were sitting on the wood, then you're not going to be able to remove that discolouration. It's caused by the reaction of the tannin in the wood with the iron ions in water which cause a compound called "iron tannate" to form, which is also called "iron gall ink". If you suspect this is the cause of that discolouration, maybe phone some hardwood flooring contractors to see if they know any way to remove iron tannate stains from wood.
Nestor_Kelebay is offline   Reply With Quote
Old 07-03-2008, 08:57 AM   #3
I think you can use oxalic acid to remove water stains; however, I believe it is also a bit toxic (although following link is a bit more optimistic):
http://www.alsnetbiz.com/homeimprove...alic_acid.html
good luck,
b
bob22 is offline   Reply With Quote
Old 07-03-2008, 11:15 AM   #4
Bob:
Not saying it won't work because I guess anything is worth a try at this point, but oxalic acid is "wood bleach". It's used to remove the grey discolouration that appears on bare wood when it's exposed to the elements.
Old 07-03-2008, 07:31 PM   #5
Wow, thanks guys. Looks like I have a couple options to try. I think I will try the bleach & or mineral spirits, because they are easily accessible. Were you suggesting I use them both & in the order you listed or one or the other? If that doesn't work, maybe I will try the oxalic acid. They are blackish stains & I know the wood was exposed to some water(but only briefly). The stains do seem superficial, more so than a plant pot stain anyway, so hopefully I will have some luck. Thanks again
Old 07-03-2008, 08:19 PM   #6
No, there's no order, and I wouldn't use them together.
What I would do, however, is use an eye dropper to put a drop of bleach on the darkest of your spots and let it sit on there for an hour or three.
Then clean that drop of bleach off and see if that spot still looks the darkest. That will tell you if the bleach is doing any good at all.
More On This Topic
Okay now before we actually begin this staining and before you actually go out and pick out your staining materials, what you need to consider is you need to think about what type of wood that you actually have and what type of stain color that you... Read More »
Wood floorings are beautiful alternatives to carpet and tile in the home. They are easy to clean and look nice. However, it is important to maintain wood floors properly. Read on to learn more. Read More »
We start off with it sanded really well and it finished up with two/twenty paper and any imperfection is out of there. For instance, it you have, just let say this piece, had some big dins in it where it was damage from a moving company or some like that... Read More »
Hard wood floors are also stained pretty easily. The first thing you can do is use a number two steel wool; this is the softest steel wool that you can find. And you’re going to dip that in a paint thinner and rub it over the stain a little bit... Read More »
In this clip we're going to look at how some of the different types of stains go onto a piece of wood. We'll take a look at the, at the oil based stains as well as the water based stains. Now, when you stain a piece of wood, you're going to make a mess... Read More »
BOSTITCH Hardwood Flooring Stapler Ciprillius Flooring 3 11-28-2007 09:16 AM
hardwood flooring over sheet vinyl floor chrish Flooring 0 09-10-2007 09:13 PM
Cost of Refinishing Hardwood Flooring ? Piney Flooring 2 03-27-2007 05:33 PM
Hardwood Flooring is one of the Most Important Design Elements in your Home Decor doctorhouse Flooring 1 12-22-2005 10:17 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
