Old 07-14-2012, 04:26 PM   #1
Removing self stick vinyl tiles from vinyl flooring
The previous owner of my home laid vinyl self-adhesive tiles over the vinyl flooring in the kitchen. I've been told the vinyl below was in good shape when she did this. Unfortunately, the self stick tiles are coming up and the corners are breaking off every time I mop! I've even cut my foot on a couple of corners. I'd like to remove the tiles and try to save the old vinyl until I can afford to replace it. Is it possible????????
mahobbs1 is offline   Reply With Quote
Old 07-14-2012, 04:36 PM   #2
Possible but not likly. Use a heat gun and a putty knife to get it off. Have a trash can handy with a liner in it to put it in.
But then your stuck with a sticky mess left on the floor from the old glue.
Mineral spirts will get it off but it's highly flamable. Open all the windows and doors, and shut off any source of an open flame, pilot lights and the water heater if it's a gas heater.
Old 07-14-2012, 04:39 PM   #3
Thanks, Joe! I knew it wasn't going to be easy, if it could be done. I'll give it a try...worst case, I have to go buy some new vinyl.
Tags
vinyl flooring
want to remove recent vinyl flooring over asbestos subfloor fabster Flooring 5 05-04-2011 02:59 PM
Vinyl tiles wont stick aparker Flooring 10 02-27-2011 09:28 PM
Removing vinyl self-stick tiles. Jim F Flooring 12 02-05-2011 07:44 AM
self stick vinyl tiles over existing linoleum? cswanson69 Flooring 1 10-26-2010 01:16 PM
questions on self stick tiles NoExperience Flooring 6 08-20-2008 01:04 AM
