Removing Rotten Bathroom Subfloor - Flooring - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-09-2011, 12:16 PM   #16
DIY staff
Rewards Points: 7,174
You got it! That should give you a nice solid base---Mike---
Old 01-09-2011, 12:50 PM   #17
Thanks Mike, I'm off to get the saw...
I'll keep the thread updated.
MoldyJay is offline   Reply With Quote
The Following User Says Thank You to MoldyJay For This Useful Post:
oh'mike (01-09-2011)
Old 01-09-2011, 01:05 PM   #18
Tileguy
JazMan's Avatar
Rewards Points: 388
Hey dude, you've had a leak for many many years.
Well, yes the subfloor should be ok as long as you add blocking under the cuts in the subfloor so both pieces are supported.
BUT, how about the joists. I will bet your present joists' framing is not sturdi enough for slate tiles. Ceramic tile or porcelain probably, natural stone? Probably not. Please tell us the type and size of the joists. Species and grade if possible. Spacing, and span from face-to-face of the two supports.
Jaz
Old 01-09-2011, 02:01 PM   #19
It looks to me like the previous owner did a quick refloor and toilet in the bathroom prior to selling to us. The leak that caused this was from a broken flange as a result of a crooked toilet. The flange was also below the level of the wood floor. I only caught this because the toilet broke. So all the seepage seems to have gone between the subfloor and the hardwood I removed. I am going to open it up right now and we will see the condition of the joists.
The joists I can see in my ductwork on the same level are 2 x 8 of what looks to be spruce. But i won't know the spacing till I open up the floor
Also the house is 22 feet deep and the joists sit on a load bearing wall
In the middle... I think
Old 01-09-2011, 02:38 PM   #20
Ok so here's a pic and it looks like the 2 x8 are 12 spacing. Good thing I do drywall because as you can see I need a ceiling. Looks like the leak was contained to right at the flange.
Rotten bathroom subfloor tallycat77 Flooring 14 02-08-2013 09:59 AM
subfloor for bathroom philmore Flooring 7 09-18-2010 09:00 AM
Sealing a bathroom subfloor? CollegeGirl Flooring 4 07-21-2009 03:50 PM
Bathroom subfloor question 2long4u Flooring 7 02-02-2009 08:47 PM
Bathroom subfloor on concrete slab question Mikedks Flooring 2 02-20-2008 07:28 PM
