Removing Rotten Bathroom Subfloor - Flooring - DIY Chatroom Home Improvement Forum
Old 01-08-2011, 09:05 PM   #1
Removing rotten bathroom subfloor
I have just discovered after trying to replace a toilet thAt the subfloor in our upstairs bathroom is rotten around the soil pipe. I have just finished adding shutoffs to the vanity so I could remove it and the flooring. Now that I have a better look at the floor I see that it is pretty bad looking up to the wall which borders my bedroom, and to the tub. I don't want to have to tear out the tub ... This was supposed to be a 30 min job to fix a toilet. Where should I tear the subfloor out to.
Also I plan to install slate tile after so I understand that also requires specific underpayment.
MoldyJay is offline   Reply With Quote
Old 01-08-2011, 09:10 PM   #2
.deleted
Old 01-08-2011, 09:13 PM   #3
Pics are here
Old 01-09-2011, 07:31 AM   #4
Please help someone
Old 01-09-2011, 08:45 AM   #5
Still need help with rotten subfloor
Please see my other thread...here are the pics... I need to know how far to rip out the subfloor...I am laying slate tile after
Old 01-09-2011, 09:18 AM   #6
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,362
If it were me, I'd pull the tub and take all the wet wood out.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 01-09-2011, 09:25 AM   #7
DIY staff
Rewards Points: 7,174
Jay---Yuck! You are not alone--this is very typical damage----
You will need to cut that back until you find good solid subfloor--Find the location of the floor joists-
Cut the bad flooring down the center of the joist--use 2x4 blocking under any seam that is not supported by a joist--Screws are best for fastening down your new plywood--Do not use OSB-it is to weak for slate-
After the subfloor is patched,add another layer of 1/2 inch B/C plywood on top,for proper stiffness.
Then 1/4 inch durrock or wonder board,set in thinset---I'll see if any one else has any suggestions.--Mike--
Old 01-09-2011, 09:53 AM   #8
The wood right by the tub does not seem to be wet just black on top from old adhesive. I've been gouging at different spots to test the wood and it seems to just be ok right beside the tub and wall, although it's definitely rotten around the pipe and a little to he right of it.
I would like a nice new base to lay my slate on anyway. Just not sure how far to cut the subfloor. It's about. 25 square feet
Old 01-09-2011, 09:58 AM   #9
Also the joists run perpendicular to the way the tub runs so you can visualize where they are in relation to the picture
Old 01-09-2011, 10:08 AM   #10
Rewards Points: 1,514
Is that a metal tub or a plastic/fiberglass tub?
If not metal I contend that the outside edge of the tub is not load bearing. Even if it is load bearing and if you have to undermine to get rid of all the rotten wood for not more than six inches along the front of the tub, then you are still okay.
I would leave at least two inches of wood in front of the tub.
It is possible that the existing subfloor is not thick enough to support slate. Too much give and the slate will crack. You might get around that by adding more joists for stiffness' sake. Extra framework of wood below and just in front of the tub would let you end the extra joists there and not remove the tub or the ceiling below.
Or add another layer of subfloor. The edge of the tub might look funny now that part of it is below floor level.
Old 01-09-2011, 10:27 AM   #11
The tub is a fiberglass whirlpool. The existing subfloor is most likely original '78, and is 3/4 ply. I have a circular saw and a recip. Saw should I leave 2 inches in front of the tub and go right to the wall everywhere else?
Old 01-09-2011, 10:34 AM   #12
DIY staff
Jay--You have duplicate posts going on the same subject---That leads to confusion--I answered this question elsewhere--Please don't do that.Mike
Old 01-09-2011, 10:42 AM   #13
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,382
Ayuh,... That duplicate thread Mike mentions is Right Here...
Old 01-09-2011, 11:45 AM   #14
Sorry about the duplicates.. My head is in too many places right now and the wife is driving me crazy. So just to clarify I should put down 3/4 ply subfloor. Then stagger the joints and lay a 1/2 of underlay, and then set 1/4 durock on a bed of thinset. And then I would assume a medium set on top to set the slate?
Old 01-09-2011, 12:07 PM   #15
Experienced
Jackofall1's Avatar
Had the exact bathroom except mirrored, heres what I did, but I removed the bath tub and built a custom shower. All the wood missing was rotten, joist were OK.
Rotten bathroom subfloor tallycat77 Flooring 14 02-08-2013 09:59 AM
subfloor for bathroom philmore Flooring 7 09-18-2010 09:00 AM
Sealing a bathroom subfloor? CollegeGirl Flooring 4 07-21-2009 03:50 PM
Bathroom subfloor question 2long4u Flooring 7 02-02-2009 08:47 PM
Bathroom subfloor on concrete slab question Mikedks Flooring 2 02-20-2008 07:28 PM
