Removing Particle Board W/ Hand Tool - Flooring - DIY Chatroom Home Improvement Forum
Old 01-17-2013, 01:56 AM   #1
Removing Particle Board w/ Hand Tool
Greetings,
I am remodeling my bathroom and looking to install tiled flooring. There is a large piece of particle board that I can't remove. The board is mounted to the floor, and I can't remove the mounting material. How can I remove the particle board without using power tools?
Many have suggested a circular saw, but I'm trying to save money. Is there a way for me to remove the particle board without using any power tools?
Thanks,
Erik
IIIErikIII is offline   Reply With Quote
Old 01-17-2013, 06:52 AM   #2
DIY staff
Rewards Points: 7,174
What hand tools do you own?
Use a brace and bit and a key hole saw---if it's glued use an adz.
Old 01-18-2013, 10:19 AM   #3
Thank you for the recommendation. I was able to remove the boards with a wonder bar, mallet, and a lot of pulling.
Old 01-18-2013, 10:23 AM   #4
Rewards Points: 13,256
And just how you you plan on doing all the other work needing to be done to do this job right without power tools?
Old 01-18-2013, 01:04 PM   #5
Rewards Points: 744
Looking to stir the pot, are we? It seems you're implying the OP hasn't thought this through.
Seattle2k is offline   Reply With Quote
Old 01-18-2013, 02:22 PM   #6
Gee you think?
Old 01-18-2013, 04:07 PM   #7
Rewards Points: 744
Well, now that the particle board is up, He/she may be able to finish the rest with just a drill (to fasten the CBU down). Possibly the OP already has a drill, is already planning the purchase of a drill, or is able to borrow one.
The OP certainly didn't say he/she is against the idea of power tools, because they are the root of all evil and are the primary cause of global warming. The OP just wanted to save some money where possible and was able to achieve that goal.
Old 01-18-2013, 04:25 PM   #8
DIY staff
Be real here---when did the first house get built in North America?
When did power tools get invented?----I knew a carpenter who could rip a board with a hand saw in less time than it took me to fetch an extension cord..
This member may not have power--or the desire to use power tools---
I just don't know some things--------------
Removing glued on carpet from partial board Southerngal12 Flooring 6 06-18-2012 01:46 PM
Ceramic Tile over plywood, particle board hardwaremanager Flooring 5 04-12-2009 10:39 PM
Melamine coated particle board - shelf abelsu Building & Construction 5 04-17-2008 04:15 PM
Particle board underlayment help diynut Flooring 5 03-07-2006 06:22 AM
particle board / hardibacker fish3211 Flooring 4 08-10-2005 09:32 PM
