Removing A Parkay Floor Over Cement - Flooring - DIY Chatroom Home Improvement Forum
Old 01-04-2009, 05:37 PM   #1
Removing a parkay floor over cement
Does anyone know of any tricks to removing a parkay floor over a cement subfloor? The flooring is in a church which had water covering two thirds of the floor from a storm. This created a bunch of popped up tiles. We fixed the leak outside and are ready to install new flooring. Since the water popped up the parkay before, we were thinking of intentionally flooding the floor for easier removal. Does anyone have any other suggestions.
crhoy is offline   Reply With Quote
Old 01-04-2009, 10:31 PM   #2
I used a heavy duty floor scraper, flat prybar, and hammer. Floor scraper is about 4' long with a handle and foot rest.
newgarage is offline   Reply With Quote
Old 01-05-2009, 06:50 AM   #3
either the above suggestion or if you bought the flooring from a place that also sells carpet they have this small tool that vibrates as it scape's for taking up carpet that was glued down.It workers great on any kind of flooring.I don't know what they call it but they should let you borrow it for a bit mine did and it made very short work of all types of flooring that was glued down
clasact is offline   Reply With Quote
Old 01-05-2009, 06:53 PM   #4
Still Learning
It really depends on how well the parquet is adhered to the concrete. Some areas may be loose while others stuck like crazy. I would avoid water, as you never know where it may travel. Under walls etc creating mold problems.
A spud bar may work or if it's like a parquet floor I pulled up about 15 years ago that was installed in the 70's, an electric jack hammer was the only solution. That was before actual hardwood flooring adhesives..and that stuff was stuck! I think it was something like 100 square feet that took 10 hours!
The other suggestions are well warranted too.
http://www.taylortools.com/prod07.html
HardwoodGuy is offline   Reply With Quote
Old 01-05-2009, 07:19 PM   #5
Norge Supply
Go out and get a couple of "shingle eaters" every roofer should have one or go out to your local Allied Building Products.
Once you get under the floor you should be able to keep tearing it up.
Norge Building Suuply is offline   Reply With Quote
Old 01-07-2009, 02:42 PM   #6
Thanks for the suggestions! I will let you know how it turns out.
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 05:24 PM
Rotten cement - skim coat or board? BradG Building & Construction 1 11-25-2007 03:25 PM
cement falling into basement from cement porch above. Betsy G Building & Construction 3 10-21-2007 01:53 PM
Removing cement walls in basement / replacing with I beam bbockstanz Building & Construction 9 11-19-2006 07:31 AM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
