Old 09-15-2005, 02:40 PM   #1
Removing paint from hardwoods
I had polyurethane put on my hardwood floors and they looked great. Unfortunately, I hadn't finished painting, so I carefully taped around the edges and primered the room.
Well, when I took up the tape, the primer had bled under it onto the floor. I don't know what to do; I don't want to scrape or sand because that will ruin the finish, but I can't have paint around the edges of all my rooms.
The paint never extends more than a quarter of an inch onto the floor and is a very thin layer. Any advice?
amclaugh is offline   Reply With Quote
Old 09-15-2005, 11:10 PM   #2
Contractor
Try some alcohol in an out of the way place. I know that it will take of the paint, just not sure of the floor. Polyurethane should take it.
Teetorbilt is offline   Reply With Quote
Old 09-16-2005, 08:45 AM   #3
Tired, Cold, and Damp
slickshift's Avatar
Oops!
...um, it's a product, I'm not saying oops you got paint on your poly lol
"Oops!" works great
Just follow the directions on the bottle
You won't need to use much or to scrub hard as the latex is new
slickshift is offline   Reply With Quote
Old 09-16-2005, 03:14 PM   #4
Floorwizard's Avatar
I know of a product that is designed to take glue residue off of poly floors. Maybe it will work on paint.
local hardware store will have it.
Floorwizard is offline   Reply With Quote
Old 09-17-2005, 09:49 AM   #5
Painting Contractor
Humble Abode's Avatar
Originally Posted by slickshift
Oops!
"Oops!" works great
Also if the coating on the floor is an oil based finish you shouldn't have to worry as products like 'OOps' and 'goof off' don't work on oil but work great on latex.
Like Teetor said try anything you use in an out of the way place first.
Bliss is a fresh piece of sandpaper.
Humble Abode is offline   Reply With Quote
Removing paint from hardware ciera Painting 11 09-10-2007 10:03 PM
Removing paint from finished wood 9c1 Painting 1 05-20-2007 07:14 PM
Removing spray paint from tools harold938 General Discussion 15 12-17-2006 08:16 AM
Removing Paint from Bricks ? Piney Painting 7 11-16-2006 02:17 AM
