Removing Old Bathroom Tile Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 08-15-2009, 08:47 AM   #1
Removing old bathroom tile floor
2nd floor bathroom. House built in 1963. Small tiles. I believe the tile was laid over a concrete subfloor poured when built. What is (if there is such an animal!) the easiest way to remove this floor? Thanks in advance for any help. Rick
rickheel is offline   Reply With Quote
Old 08-15-2009, 10:45 AM   #2
Rick - Check out the Artillery tool system. It will take care of that tile without any problem. But if you are just doing 1 bathroom and dont want to fork out a couple hundred bucks for tools, just get a stanley wonderbar, a stone chisel, a rubber mallet and your basic hammer . While it is tempting to just get in there and break all that crap out, go slow and with method. Good luck.
BBC Carpet One is offline   Reply With Quote
Old 08-15-2009, 06:40 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
HOLD ON!!!
If this is a second floor bath it's unlikely there is a concrete floor unless you have an old-fashion "mud-job" or are living in a condo.
If this is a condo you need to regroup before to take out anything. There are rules.
If this is a wood structure with cement board a hammer and chisel should do the job.
If this is a wood structure with a mud-job" you aren't likely to get the tile out without destroying the mud-job so...
Go rent an electric chipping hammer and go after the whole thing all at one time.
Trouble with that approach is now you have to redo the mud-job before new tile can be installed.
So.....the question is...
Which is it?
XXX
concrete floor in bathroom cmt9000 Flooring 3 04-27-2009 06:37 PM
Removing concrete slab on 3rd floor bathroom NowItsShowtime Flooring 2 03-26-2009 02:17 PM
Busting out my shower tile floor and walls. caliskier Building & Construction 3 03-15-2009 08:59 AM
Tile over existing tile floor? dwalls32 Remodeling 3 07-03-2007 04:19 PM
old uneven bathroom floor toubob Flooring 4 02-15-2007 01:39 PM
