-   -   Removing old adhesive for new self-sticks? (http://www.diychatroom.com/f5/removing-old-adhesive-new-self-sticks-150319/)
Baldrick63 07-15-2012 09:26 AM
Hi all.
My kitchen has 5/8" plywood sub floor, 5/8" plywood underlayment, linoleum tile, luan, and finally vinyl tile.
I'd like to take it down to the underlayment and install something like the Ceramica self-sticks.
The problem is, after removing the linoleum, there's a black adhesive that looks almost like a thin asphalt layer. It comes up pretty good with GooGone, but it leaves a black greasy residue that I know the new tile won't adhere to.
I'd rather not put new underlayment down for height reasons. What would be the best way to prep the plywood for tile? Should I use a solvent to get up what I can and then sand until I hit clean plywood? Or is there a primer that would work? If I had to go with new underlayment, what's the thinnest stuff that would work?
Any ideas would be great!
Thanks.
joecaption 07-15-2012 09:45 AM
You would be far better off removing that whole layer of laun.
Any peel and stick needs a perfectly flat clean surface.
Is that Ceramica a peel and stick tile?
If so please do not install it. Most peel and stick tend to shrink so gaps open up, there a pain to install because they stick so fast so it's near impossible to keep a straight line, look around on this site and almost any DIY site and see all the people trying to get rid of it because it's failing.
A quality sheet linolium, laminite that looks like tile or even glue down 12 X 12 tiles would hold up far better.
Baldrick63 07-15-2012 09:48 AM
After doing some research, I guess I've got what's called cut-back adhesive.
Perhaps I'd be best off by removing everything down to the cut-back and putting the thinnest underlayment down.
Suggestions?
joecaption 07-15-2012 09:50 AM
1/4 sanded underlayment rated plywood, NOT LAUN!
Baldrick63 07-15-2012 10:25 AM
Sorry for the misunderstanding. The old luan is definitely going. I've got old tile on both sides of the luan. Underneath the bottom tile is the cut-back whick sits on the 5/8" plywood underlayment.
Trafficmaster Ceramica is the newer vinyl tile that can be put down with spacers and grouted. See it here: http://tinyurl.com/769vrse
I can't find out too much on the stuff - maybe since it's pretty new. I sure looks nice though - not to mention cheaper than other options.
joecaption 07-15-2012 11:10 AM
Not going to like it, the grout will not hold up. Been there tryed a product like it.
My local HD and all the installers I deal with refuse to install it.
If you looking for a simple to install floor that looks like tile concider a laminite that looks like tile.
Easy to install, will go right over the old cut back if you can get most of it off with a razor floor scraper.
I've done several floors with it and have had no issues or call backs.
It will even have what looks like grout lines.
I had some left over from a job and installed it in my own bathroom 5 years ago and it still looks like new. I never would suggest anyone use laminite in a bathroom, but ha, it was free so I thought I'd try it.
rusty baker 07-15-2012 01:01 PM
Remember too, the cutback will most likely contain asbestos.
