Removing Mortar - Flooring - DIY Chatroom Home Improvement Forum
Old 12-15-2013, 04:28 PM   #1
Rewards Points: 205
Removing Mortar
I know there is no easy way to remove this stuff. I'm looking for the most efficient. Tile set over other tile. I used a little muriatic acid and water solution to scrape off some of this but the job seems tedious.
Should I use a wet sand paper in combination with the solution?
Any thoughts?
CosmicMiami is offline   Reply With Quote
Old 12-17-2013, 01:58 PM   #2
Rewards Points: 336
Are you trying to save the bottom (now exposed) layer of tile? Or are you trying to just prep that layer so that you can do a new second layer of tile?
If the latter, I don't see it being a good idea to ever try applying tile over an existing tile layer.
JKeefe is offline   Reply With Quote
Old 12-17-2013, 03:35 PM   #3
Rewards Points: 205
I am wanting to save the tile. I have already used water and and small chisel/scraper. I also applied a solution of muriatic acid that did a decent job. I guess my question is, would a wet sandpaper work any better so on a palm sander?
Thanks.
Old 12-17-2013, 04:30 PM   #4
Rewards Points: 336
I would think sanding would leave marks in the bottom tiles. If you've got something that works, keep at it. A job like this is never fun.
I doubt you'll ever get anything out of the grout...
Old 12-17-2013, 05:19 PM   #5
Rewards Points: 205
The small part I did with the acid solution made the grout look pretty good.
Old 12-21-2013, 09:31 PM   #6
never seen anyone tile over tile before. if the muriatic acid works, it's probably your best bet.
neight is offline   Reply With Quote
Old 12-22-2013, 07:54 AM   #7
Rewards Points: 205
To be sure, I did not set this tile over tile. Believe it or not, it's not that uncommon here in SoFla. I've seen it a few times.
Replace mortar between stones in fireplace hearth support dm1337 Concrete, Stone & Masonry 3 06-17-2012 11:41 AM
Removing Old Mortar elbow_grease Building & Construction 2 12-23-2011 11:37 PM
Match mortar jskamm Building & Construction 3 06-07-2009 03:01 PM
Bond strength of mortar??? figs Building & Construction 7 06-06-2009 04:23 PM
Removing mortar left behind dankreboot Flooring 2 04-01-2009 07:53 PM
