Removing Masonry Nails - Flooring - DIY Chatroom Home Improvement Forum
Old 09-07-2009, 03:53 PM   #1
Removing Masonry nails
After some basement flooding, my wife and I pulled up the carpeting to reveal bare concrete. We'd like to either re-carpet or tile the floor, but when I pull up the wood border, there are large nails which protrude about 1/2" from the floor. I'm unable to pull up these nails by hand, so my question is, what power tool could I rent or buy that would either pull up these masonry nails with minimum damage to the concrete or cut them off so they're flush (or nearly flush) with the floor level. Thanks very much!
davesink is offline   Reply With Quote
Old 09-07-2009, 03:59 PM   #2
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Hit the protruding nail heads on one side with a hammer then the other side. They will break off.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 09-07-2009, 04:06 PM   #3
Thanks, PaliBob. I'll give it a go! Sounds like safety goggles are definitely a must.
Old 09-07-2009, 08:32 PM   #4
Pulling those hard nails...
I think that you could also use a brand new hand tool on the market called the Nail Jack, a pliers like approach where instead of a cat's paw, which can't grab or squeeze against the exposed shaft of a nail, these tools contain a built in fulcrum and you can squeeze, push down the handles and lift those nails out!
www.thenailjack.com
axxmannnn is offline   Reply With Quote
Old 09-07-2009, 10:17 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Jheeeeesch!
Do as Bob said. Those nails will break out immediately. You don't need no fancy tools.
That nailjack looks like one helluva handy tool, may have to have one of them. It wouldn't work for this purpose tho.
XXX
Forgot to use galvanized nails... healeypd Building & Construction 8 05-12-2009 10:10 AM
removing damaged deck nails DaveHome Carpentry 6 05-05-2009 07:44 PM
What nails to use? 2x4 framing, osb sheathing jw15842 Carpentry 6 09-08-2008 11:31 PM
Rusty nails FatAugie Roofing/Siding 6 08-28-2007 10:25 AM
Which nails are right for the job? MIKEGOUGH1 Building & Construction 2 12-16-2006 11:54 AM
