Removing Linoleum Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 10-08-2009, 08:05 PM   #1
Hi Everyone
I'm trying to prep my floor for acid staining. I used to have linoleum flooring down (12" x 12" squares). I have pulled that up and removed the glue but the design of the linoleum is still on the cement. Probably cause it was on for over 10 years.
I was going to sand the floor to get rid of the design but I have read that if you sand the floor before acid stain that the stain wont work.
Any Ideas on this?... How to remove the design?
Bobby
CaWingz is offline   Reply With Quote
Old 10-16-2009, 07:10 PM   #2
My experiences with the ghosting of a tile grid is that they dont go away. We did an office building where the polishing/profiling contractor i hired ground into the aggregate + it was still there... up to an 1/8" into surface. Overlaying the concrete is your best bet to get rid of it. We had to do some master trickery to even cover the grid with waterbased stains + had little show.
user64621 is offline   Reply With Quote
Laminate flooring over linoleum and particle board no_spare_time Flooring 3 06-07-2009 11:54 PM
Removing Vinyl Tile Adhesive from Linoleum The Raven Flooring 3 07-22-2008 08:38 PM
Question about linoleum flooring JZ2008 Flooring 2 02-24-2008 07:59 PM
Removing Wood Flooring - Cutting Close to the Edge of the Wall rgmetro Flooring 2 07-12-2007 06:21 AM
Removing Linoleum backing paper from wood floors SatDoug Flooring 4 09-16-2006 11:00 PM
