Removing Laticrete Fortified Thinset - Flooring - DIY Chatroom Home Improvement Forum
Old 02-03-2013, 04:08 PM   #1
Installed 18 x 18 porcelain with sanded grout by contractor. Didn't like it. Removed it and ground the floors down to remove thinset.
Later installed 18 x 18 porcelain with "laticrete fortified" thinset. Had moisture issue and needed to remove 2nd installtion of tiles.
However, the laticrete thinset will not come up. I used a diamond stone grinding blocks and the SCARIFIERS on the same grinder. The stones just gunked up and didn't remove the thinset, and the scarifiers only knocked down the thin set - sort of.
What in the world can I do to get this stuff up so I can level it and put down laminate planks? Thanks for your help.
kathy3of4 is offline   Reply With Quote
Old 02-03-2013, 04:18 PM   #2
DIY staff
Rewards Points: 7,174
This Latacrete product--did it come premixed in a bucket?
Old 02-03-2013, 04:19 PM   #3
Rewards Points: 12,804
What is the thin set attached to? Is there tile board under it?
What do you mean by you had moisture issues?
Old 02-05-2013, 10:46 AM   #4
Can't get up laticrete thinset
The thinset came dry, I mixed it. It was applied to a cement slab and I back buttered the porcelain tiles. There was moisture rising up from under the slab that loosened the thinset forcing me to remove all of the tile.
I had to have back surgery and never got back to removing the thin set for months, that's when I rented the grinder and learned that it's not going to come up.
Old 02-05-2013, 10:55 AM   #5
DIY staff
Did the grinding cup look something like this?
I've also used a commercial floor buffer with a set of carborundum stones---this worked very well,but the area was large---not sure how well it would work in a confined space.
Sorry to hear you are having trouble---that is unusual.
Removing epoxy Laticrete spectralock grout MAJinSEA Flooring 5 10-03-2011 11:50 PM
removing thinset from old wood floor annskigirl Flooring 1 05-21-2011 06:41 AM
Removing Thinset from Badly Installed Tile bobbygarafolo Tiling, ceramics, marble 2 04-21-2010 02:29 PM
Removing old thinset from subfloor gburg3 Flooring 3 12-15-2008 08:59 PM
Fortified Thinset poolecw Flooring 4 10-31-2008 08:06 AM
