-   -   Removing Laticrete Fortified Thinset (http://www.diychatroom.com/f5/removing-laticrete-fortified-thinset-170924/)
kathy3of4 02-03-2013 03:08 PM
Installed 18 x 18 porcelain with sanded grout by contractor. Didn't like it. Removed it and ground the floors down to remove thinset.
Later installed 18 x 18 porcelain with "laticrete fortified" thinset. Had moisture issue and needed to remove 2nd installtion of tiles.
However, the laticrete thinset will not come up. I used a diamond stone grinding blocks and the SCARIFIERS on the same grinder. The stones just gunked up and didn't remove the thinset, and the scarifiers only knocked down the thin set - sort of.
What in the world can I do to get this stuff up so I can level it and put down laminate planks? Thanks for your help.
oh'mike 02-03-2013 03:18 PM
This Latacrete product--did it come premixed in a bucket?
joecaption 02-03-2013 03:19 PM
What is the thin set attached to? Is there tile board under it?
What do you mean by you had moisture issues?
kathy3of4 02-05-2013 09:46 AM
Can't get up laticrete thinset
The thinset came dry, I mixed it. It was applied to a cement slab and I back buttered the porcelain tiles. There was moisture rising up from under the slab that loosened the thinset forcing me to remove all of the tile.
I had to have back surgery and never got back to removing the thin set for months, that's when I rented the grinder and learned that it's not going to come up.:(
oh'mike 02-05-2013 09:55 AM
https://encrypted-tbn1.gstatic.com/i...GpYyY9JYzP2mDg
Did the grinding cup look something like this?
I've also used a commercial floor buffer with a set of carborundum stones---this worked very well,but the area was large---not sure how well it would work in a confined space.
Sorry to hear you are having trouble---that is unusual.
