Removing Glued On Outdoor Carpet From Concrete Steps - Flooring - DIY Chatroom Home Improvement Forum
Old 11-28-2009, 12:59 PM   #1
Question
Removing glued on outdoor carpet from concrete steps
I have a large concrete front stairway which was completely covered in outdoor carpet by the previous owner. The guy who did the inspection for me said that is a big no-no for concrete, & it appears to have started to deteriorate in places already. The trouble is that whatever glue they used will probably hold until the next ice age!! I just can't figure out how to get this stuff off. Is there any type of glue solvent out there, or some sort of product which will help to remove it? ... Any ideas or input appreciated.
churchlady is offline   Reply With Quote
Old 11-28-2009, 01:26 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 182
First of all, I have installed thousands of yards of turf on concrete, Won't hurt it at all, except it's ugly. I know of some mini-golf courses that have been carpeted for 30 years or more. A scraper is the way i usually take it off, but you can go to a carpet store, not a big box, and get some adhesive remover.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 11-28-2009, 03:33 PM   #3
Kekeever
Kyle Keever's Avatar
If its old and brittle a floor sander could grind it off.
Kyle Keever is offline   Reply With Quote
Old 11-30-2009, 11:03 PM   #4
Thanks rusty & kyle,
I think the adhesive remover sounds less labour intensive (its a large carpeted area remember) Will give it a try when weather permits, cause that carpet has got to go. Not only does it look nasty but its also torn and a tripping hazard at this point. Wish me luck ...
Help on removing concrete stairwell going into Basement. earthad1 Building & Construction 13 03-29-2010 01:59 PM
Rebuild concrete steps leading to basement gruntman Building & Construction 32 09-30-2009 11:55 AM
forms for semi-circular concrete steps cirsteps Building & Construction 7 10-22-2008 11:22 PM
Concrete steps Shadowchase Building & Construction 5 07-04-2008 06:01 PM
