Removing Glued Hardiebacker Board - Flooring - DIY Chatroom Home Improvement Forum
Old 08-02-2008, 11:57 AM   #1
Unhappy
Removing glued hardiebacker board
We are replacing our ceramic tile kitchen floor with hardwood. The tile is coming up in whole pieces, however the hardiebacker board is nailed and glued to the sub floor. Does anyone know of an easy way to get this stuff up. It just seems to crumble into tiny pieces. It is taking an incredibly long time! Please we need HELP!
labaldi is offline   Reply With Quote
Old 08-02-2008, 12:09 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
There is no "easy way".
We use what is called a "heavy-bar" and just go after it. We also have an air driven standup chisel that works well. But "IT AIN'T CHILDS PLAY".
Once the backer is out of the way the screws can be broken off if need be.
Ridge board enough? runningforyou Roofing/Siding 9 08-13-2008 07:43 PM
removing panel board from behind backsplash MJ1 General DIY Discussions 3 11-18-2007 09:42 AM
Removing water stains bead board Mikon Painting 5 10-08-2007 04:57 PM
removing glued wainscoating diysteph General DIY Discussions 4 07-16-2007 04:38 AM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 10:50 PM
