Removing Glued On Carpet From Partial Board - Flooring - DIY Chatroom Home Improvement Forum
Old 06-15-2012, 11:50 AM   #1
Removing glued on carpet from partial board
Help! We are removing carpet tht has been EXTRA glued on. It is back breaking! we need some answers..is there an easy way of removing this? can anyone help me?
Southerngal12 is offline   Reply With Quote
Old 06-15-2012, 03:09 PM   #2
Rewards Points: 1,574
Likely no.
What are you going to put down to replace the carpet?
Might have to get rid of the particle board in any case IMO.
bob22 is offline   Reply With Quote
Old 06-15-2012, 05:19 PM   #3
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 56
If you are installing tile, the particle board must go anyway.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 06-15-2012, 08:34 PM   #4
Rewards Points: 13,300
I agree, I would not waste my time trying to get it off. Partical board is one of the lamest ideas ever came up with.
It's not a sutable subflooring for any flooring.
It gets wet just once and it turns to oat meal.
Old 06-17-2012, 06:40 PM   #5
We are putting down Laminate wood floors. When we pull up the carpet some on the partial board comes with it. its such a mess!
Old 06-17-2012, 09:36 PM   #6
Then take the time to do it right and rip it all out now before it becomes an issue later on.
There is just 0 reasons to keep a partical board subfloor.
rusty baker (06-17-2012)
Old 06-18-2012, 01:46 PM   #7
I agree with the others. i would just remove the particle board too.
RhodesHardwood is offline   Reply With Quote
Problem with carpet glued to asbestos tile and want to replace... bobcaryh Flooring 7 11-29-2011 01:15 AM
Removing Carpet Adhesive glyndwr Flooring 0 10-20-2011 11:37 PM
Carpet cleaning - sump water n0c7 Flooring 17 08-29-2011 08:04 AM
removing panel board from behind backsplash MJ1 General DIY Discussions 3 11-18-2007 10:42 AM
Removing water stains bead board Mikon Painting 5 10-08-2007 05:57 PM
