Removing Glue From Hardwoods - Flooring - DIY Chatroom Home Improvement Forum
Old 05-23-2008, 02:59 PM   #1
removing glue from hardwoods
i have recently purchased my first home and found that under the carpet is hardwood flooring. in the foyer a past owner glued parquet flooring on top of the hardwoods. i dont know exactly what type of glue it is or how old it is, but the glue has dryed white and is kind of foamy. is there anyway to get the glue off the hardwood without damaging them? am i going to have to sand it off? any help would be greatly appreciated.
david81 is offline   Reply With Quote
Old 05-23-2008, 11:40 PM   #2
Registered User
Termite's Avatar
If it is foamy that makes me think it is polyurethane glue. I doubt you'll be able to remove it from your hardwood without re-finishing.
I'd say try laquer thinner, but that will booger the finish of the hardwood beneath. Chances are, the poly glue already did that anyhow.
Old 05-24-2008, 10:37 AM   #3
if laquer does not do the trick is there anything else i could try? is there anthing i should not try? is there any type of chemicals that will damage the floors beyond repair?
Installing glue down engineered floor brad4499 Flooring 6 03-12-2008 09:54 AM
Wood Glue Issue gp1200r Carpentry 4 02-20-2008 11:56 AM
removing OSB Underlay?? maikenh Flooring 1 12-23-2005 09:28 AM
Removing paint from hardwoods amclaugh Flooring 4 09-17-2005 08:49 AM
