-   -   Removing glue from hardwood floors - sanding? (http://www.diychatroom.com/f5/removing-glue-hardwood-floors-sanding-62377/)
jbitt 01-20-2010 01:54 PM
Hello all,
I had parquet flooring in my house which was covering the original hardwood floors. The parquet was glued down and came up pretty easily with a hammer and prybar, but i'm left with all the adhesive that was used to glue down the parquet.
I want to save the original hardwoods and refinish them. What is the best way to remove the glue or adhesive that is left? Will the large floor sander (the walk behind kind you can rent from home depot) do the job?
jlhaslip 01-20-2010 04:12 PM
that floor sander will remove it just fine.
use the walk behind PAD sander (not the drum style) and 36 grit the glue spots before doing the bulk of the floor.
resume with 50 or 60 grit to surface the floor and continue with higher grits until you are happy enough.
stain and finish accordingly.
have fun. :)
pinwheel45 01-20-2010 05:10 PM
Really depends on what type of glue was used to glue down the parquet. If it was water based, a drum sander will remove it. If it's solvent based, you'll need adhesive remover to disolve the glue. Best way to tell the difference is if the glue is kinda gummy when ya scrape it with a knife blade, it's solvent based. If it powders up with scraping, it's water based & will sand just fine.
