Removing Glue From Concrete - Flooring - DIY Chatroom Home Improvement Forum
Old 08-24-2007, 10:51 PM   #1
Removing glue from concrete
I know this is prob something I shouldn't attempt, but alas, I have no choice..........We had to dig up our bathroom floor because of drain issues..........since the concrete is redone.......the rest of the floor was sheet flooring........My husband and I pulled it up thinking.....no big deal.......(Mr. clean and a scraper got of the glue residue from the carpeting).............this was MUCH worse. There was a strong odor....and My honey ended up cutting up some really thick boxes and covering the floor with that until I figure out what to do....(he just left today for Iraq and will be gone longer than I can wait)....I have some stuff that is "supposed" remove any kind of floor glue.......but it seems messy and I am totally intimidated by that........I am hoping someone can tell me how simple this is really going to be. I plan to paint/stain the concrete when I get the glue off.
boomer0369swife is offline   Reply With Quote
Old 08-25-2007, 12:49 AM   #2
Re: Removing Glue from Concrete.
Can I ask what exactly you removed and how old it was? Was it sheet vinyl or commercial vinyl tiles (those will be hard and brittle)? Did it come up in layers or was it brittle? What color is the adhesive left behind? What product did you buy to remove it? For the most part, lots of elbow grease and a good floor scrapper will do the trick. There is a product that does quite well called "Foam Off". It removed most mastics, but is in liquid form so it will be messy. It's important to know what kind of flooring and adhesive it is so that you can make sure the remover you have will work and not just get it wet. HTH
Solosrose is offline   Reply With Quote
Old 08-25-2007, 01:58 AM   #3
We had to pull it up eventually. The plumbers had to jack hammer through the concrete in there to reroute the bathroom drains. The repair ran right down the middle of the bathroom floor.........sheet vinyl was only left in front of the potty and over by the sink. It was really ugly anyway. I eventually want stone tile.......but have to wait awhile and decided just to paint it. Not sure the exact product we bought to remove it, but the guy @ the store recommended it for most adhesives. The color is white to yellow in spots.........the concrete underneath is also in need of repair in spots. We live in southern California and have several cracks that we have to repair before putting any other flooring down. Just not sure how messy this is going to get.
Old 08-27-2007, 12:31 AM   #4
Iíve been redoing a bathroom on my lower level with a concrete floor and had to remove old vinyl that was glued down. I think the reason for the question of the color of the glue relates to if it might have asbestos in it. That could pose a health risk. From my Google research white likely doesnít and black likely does.
I tried some adhesive remover that didnít do much on the white adhesive. It worked well for removing any bits of the vinyl that remained stuck. Also Iím titling an adjacent entry area that had indoor/outdoor carpet glued down. The remover worked well on the old sticky carpet foam but again not on the white glue.
What worked well for my job on the white glue was water and a wire brush. I soaked the area with water for about 15 minutes and then scrubbed by hand with a wire brush and mopped with a damp sponge. I recommend that you try it before trying harsh and expensive chemicals. You can also use an angle grinder with a wire brush cup but I donít recommend using an electric tool on a wet floor and doing it dry will raise more dust than you or I will want to deal with.
Also if you plan to tile the floor I wouldnít paint or stain it. You will just end up having to clean it off to get a good bond with the tile thin set mortar. The use of all the paint and chemicals can soak into the pores of the concrete and inhibit the bonding of the thin set. I suggest throw rugs and live with bare concrete until you can do the tile. BTW, tile isnít all that hard to do if you do your homework. Home Depot folks are a good resource and you have a support system with this forum.
And thank you and your husband for his service to our country and your support.
Tom Highway is offline   Reply With Quote
Old 08-27-2007, 03:21 AM   #5
Thanks..........Right now......lol......I have a big waxy cardboard box taped over the nasty crap and throw rugs on that .. ........but come next weekend.......I am going to have to deal with it. Concrete IS easy to clean........and my kids are learning to be careful......lol.....its also very hard......I will def try that and let you know........the glue is white in most places, then some is yellow.......but considering the plumbing issues that have apparently gone on for awhile.........could explain both the color of parts and that smell.........?
J
Old 08-27-2007, 09:21 AM   #6
The pros would dry scrape with 4" razor scrapers. Have a fox tail brush to get the dust. Do not paint concrete if you want to thin-set and tile in the future.
( thin-set will not adhere well to the paint.) why don't you loose lay some indoor outdoor carpet. you could save this project for hubby, another good reason for him to stay safe and get home.
May God Bless and keep you all safe.
Big Bob is offline   Reply With Quote
Old 08-27-2007, 11:30 AM   #7
Unhappy
removing glue from concrete floor
having a hard time removing pilled on yellowish glue from concrete floor..am removing vinyl tile...any sugestions!!
dianagon336 is offline   Reply With Quote
Old 08-27-2007, 11:37 AM   #8
Oooo if I could stand it that long.....lol. He has enough to do when he gets back........I have a fence project on his honey do list. I am trying to stay stupid busy while he is gone so I don't freak out.........
diana.......did your glue stink? hard to explain the smell, but it burned my nose and just smelled like something really foul.
Old 08-27-2007, 04:26 PM   #9
No clue about the glue. However, I have heard of local groups who help the families of deployed soldiers. I did a VERY quick search and came up with nothing but people and places do exist. Tap into the families of deployed soldiers network and see what you come up with.
Take care and good luck!
Concordseeker is offline   Reply With Quote
Sleeve options for plumbing through concrete? Bruce L Plumbing 6 06-14-2008 09:38 AM
Removing concrete forming? MLO Building & Construction 3 10-01-2006 10:30 AM
stone veneer formula tom1st Landscaping & Lawn Care 1 07-08-2006 04:48 PM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 10:27 PM
