Removing Floating Timber Floorboards - Flooring - DIY Chatroom Home Improvement Forum
Old 07-23-2009, 06:28 AM   #1
Removing floating timber floorboards
Hi Guys,
I am hoping someone can help. I am trying to remove my existing floating timber floorboards. The floorboards themselves are not glued or nailed down to the existing surface, which is concrete, so it is no problem getting underneath the boards themselves. The issue is dismantling them. Ideally I would like to onsell them, but unless I get some advice, I am going to use the old brut force approach, which will render them useless.
The boards are attached via a tongue and groove joint and are proving exceedingly difficult to separate.
Any advice would be welcomed. I would consider myself an amatuer DIYer, at best.
Cheers
rickybraz is offline   Reply With Quote
Old 07-23-2009, 07:11 AM   #2
If nothing is nailed, and you can't separate them, I assume they are glued together. If that is the case, there is no simple way, force is needed. You will probably get some apart without too much damage, but I suspect a lot will have tongues ripped off.
Old 07-23-2009, 07:21 AM   #3
Hi Bill, thanks very much for your response. I have been able to extract one section of board, using force, and it does appear to contain traces of glue.
Thanks again
Engineered, floating hardwood or glue-down gosooners Flooring 5 04-22-2009 01:26 AM
Timber retaining wall repair *Kennedy* Landscaping & Lawn Care 2 03-26-2009 07:02 PM
Trying to install floating floorboards... Hyperian Flooring 4 06-22-2008 05:11 AM
Installing an island on floating engineered wood floor funktional Flooring 11 03-14-2008 07:19 AM
