Removing Concrete Sealant And Leveling - Flooring - DIY Chatroom Home Improvement Forum
Old 08-02-2012, 03:01 PM   #1
Removing concrete sealant and leveling
So we have a patio we had enclosed a few years ago, we sealed the concrete then had carpet put down. We are now removing the carpet (not totally sure what we are going to do - we are open to suggestions, keeping in mind multiple dogs and small children), and want to level the concrete with the self-leveling cement. I have done a bit of research and am not sure what would be easier and safer (we have 3 dogs). Sanding the concrete or acid-etching it. It is 20'x25'.
I am pretty handy around the house for a woman (I have poured concrete and just recently laid ceramic tile in 2 bathrooms) and always up to learning how to do new things. Any suggestions or help would be appreciated. I am located in northern Utah.
Leisha70 is offline   Reply With Quote
Old 08-02-2012, 08:14 PM   #2
Rewards Points: 13,446
If that carpet is glued down your in for a fun job trying to scrape off all that old glue.
I'd forget about the acid etching and concider tile instead.
Reason being acid etching will require a perfectly clean surface, not likly after glues been applyed.
Tile will hold up great with kids and dogs, it's aslo easy to just sweep up.
Old 08-04-2012, 08:28 PM   #3
Rewards Points: 3,520
If the carpet is not glued down,you can't use a self leveling product until you remove the sealer,or scarify the surface.
Canarywood1 is online now   Reply With Quote
Old 08-04-2012, 11:06 PM   #4
thanks - the carpet is only glued around the edges. I ended up renting a sander/buffer with this diamond grit. It worked really well on removing the sealant and almost all of the glue.
Gluing wood to concrete timbo59 Flooring 5 12-22-2011 10:15 AM
Proper methods to fill concrete gaps, holes, cracks and resurface concrete jzam42 Building & Construction 6 07-21-2010 11:50 AM
Crack filling concrete control joints MI-Roger Building & Construction 11 09-22-2009 06:00 AM
Concrete basement floor patching Village Man Flooring 4 09-16-2009 07:15 PM
Concrete stain on painted sloped floor ur_real_dad_21 Flooring 4 01-09-2009 11:38 AM
