Removing Color From Colored Grout - Flooring - DIY Chatroom Home Improvement Forum
Old 10-16-2009, 07:19 PM   #1
Removing color from colored grout
I recently installed tile for the first time in my laundry room. The tile job turned out okay but the grout dried blotchy. It was supposed to be a gray color called oyster gray but it basically dried bright white with spots of gray. I have tried some basic scrubbing and the white doesnt go away. I have not sealed the grout yet. Its been about 1 month since I installed the grout. I havent tried the acid route to see if the problem is possibly efflorescence. I actually like the look of the grout being a light color and i was wondering if there is an easy way to completely *bleach* the grout a single light color?
I just tried applying bleach to a small test spot and I am waiting for it to dry to see the results. I was wondering if anyone knows a good way to remove the color from the grout (bleach, prioxide, acid, etc). Also any techniques i should do or not do.
Thanks. Jeff
jeffmn is offline   Reply With Quote
Old 10-16-2009, 09:20 PM   #2
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
Try this: http://www.custombuildingproducts.co...er=pro&lang=en This is an epoxy grout sealer that will recolor the grout as you seal it. This will take care of sealing and coloring all at once. It'll work a lot better than trying to bleach it.
Darkling Designs
poppameth is offline   Reply With Quote
Old 10-16-2009, 10:10 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 220
YUP, the colorant is the way to go.
Jaz
JazMan is online now   Reply With Quote
Removing cured grout from surface of slate tiles Mikedks Flooring 5 09-28-2009 01:38 PM
Removing water stains for shower tile grout? acyate General DIY Discussions 2 08-07-2009 07:38 PM
Tinting/re-coloring grout proofer Flooring 7 02-02-2008 11:59 PM
Difficulty removing grout ????????? nsb318 Flooring 12 02-19-2007 11:47 PM
