Removing Ceramic Tile From Subfloor - Flooring - DIY Chatroom Home Improvement Forum
Old 06-05-2008, 12:28 PM   #1
Removing Ceramic tile from subfloor
Hi;
I have ceramic tile in my kitchen which is badly cracked due to the subfloor having a hump. It is six by six tile, and I would like to remove it from the kitchen floor and replace it with cork or wood plank flooring. I would like to try to salvage the undamaged tiles to repair the rest of the floor adjacent to the kitchen. Does anybody have any suggestions for removing the undamaged tiles without destroying them in the process?
Gerry
Gerry Kiernan is offline   Reply With Quote
Old 06-05-2008, 12:42 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 290
If it had been installed right you'll have a hard time saving many if any. No way to know until you start removing. It also depends on what the tiles are set over and with what. I would say you should be able to salvage some with luck.
Old 06-05-2008, 01:19 PM   #3
Thanks for the response JazMan.
You are likely right, but I'll give it a try. As far as I know the subfloor is plywood. I'll know for sure once I start.
Gerry
Old 06-06-2008, 12:33 AM   #4
Floorwizard's Avatar
Some just may come off OK.
Then to take the thinset off the back off the tile.......yowch
Floorwizard is offline   Reply With Quote
Old 06-06-2008, 09:55 AM   #5
I hope you're having better weather up there than we are down here. We are calling this month Junuary so far. Not the best biking weather.
Gerry
Ceramic tile over existing (full mud) ceramic? rjniles Flooring 7 12-24-2008 07:12 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 04:31 PM
Removing Ceramic Tile csnolan General DIY Discussions 1 10-26-2007 11:37 PM
Removing Ceramic Tile Blaze25 Flooring 2 11-16-2006 09:52 PM
is this subfloor strong enough for ceramic tile ? mf915 Flooring 2 07-01-2006 08:02 AM
