Old 09-07-2008, 02:28 AM   #1
Removing caulk from paint
I installed my baseboards after carpet was laid down and walls were painted, used white DAP caulk to fill(white baseboards). I wiped the walls down with a sponge, but even with a clean sponge it still left a half inch or so shiny trace right above the baseboards on the paint. Anyway to remove this without repainting?
n0c7 is offline   Reply With Quote
Old 09-07-2008, 12:28 PM   #2
poppameth
Guest
Posts: n/a
No. You'll have to touch it up. Acrylic caulk on acrylic paint bonds when it sets. You either keep it off the paint to begin with or touch it up afterward.
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 08:46 PM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 11:43 AM
Flashing NoExperience Painting 13 09-04-2008 06:56 AM
oil base paints NoExperience Painting 30 09-04-2008 06:37 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 08:18 PM
