Old 09-28-2009, 11:33 PM   #1
Removing carpeting adhesive from wood stairs?
I removed the old carpets from my staircase and the underyling wood looks in real great shape, so I will refinish and clean up and leave just like that. The only question I have is: what is the best way to remove the remnants of the glue that was used to secure the padding in place?
- I read that Krud Kutter is good.
- What about Goo Off. Is it too strong, will it stain the wood?
- Or what about just light sanding?
Like I said, I will be refinising the wood, so minor issues resulting from the removal of the glue are not that big. I just don't want to completely ruin the wood.
Thanks in advance.
P550 is offline   Reply With Quote
Old 09-29-2009, 04:46 AM   #2
Tool Geek
PaliBob's Avatar
P550, I like WD-40 as a general purpose lube, cleaner and protector.
I buy it in gallon cans and mostly use it in a spray bottle.
http://www.wd40.com/files/pdf/wd-40_2042538679.pdf
The Spray Bottles are sometimes hard to find.
I think the retailers would rather sell WD-40 in those big markup aerosol cans.
http://www.amazon.com/WD-40-10000-Sp...211540&sr=1-12
& Stay Safe
.....Bob Lavery
Old 09-29-2009, 06:49 AM   #3
sdsester's Avatar
I have used Krud Kutter and it works reasonably well. Test the wood though to make sure you do not get staining.
sdsester is offline   Reply With Quote
Old 10-02-2009, 08:33 AM   #4
Really depends on if it was a water based carpet glue, or solvent based. If it's water based, it will shatter when ya sand the floor with a drum sander & not clog the paper. If it's solvent based, you'll need to use a carpet adhesive remover. You should be able to buy it from most carpet retailers. Mine carries it in the 5 gallon container. If you have to go that route, be sure to ventilate the area well & wear the appropriate respirator. That stuff is nothing to play with. It'll make ya loopy in a matter of minutes.
pinwheel45 is offline   Reply With Quote
Carpeting Stairs - Tips 'n' Tricks? DanTheMan Flooring 1 08-20-2008 09:58 AM
Removing wall under stairs Lankston Building & Construction 3 06-10-2008 08:50 AM
Wood stair covering...pergo? DK75 Carpentry 6 11-02-2006 11:51 PM
Removing Linoleum backing paper from wood floors SatDoug Flooring 4 09-17-2006 12:00 AM
Wood to Concrete without Drilling MattStata Carpentry 1 04-19-2006 05:16 PM
