Removing Carpet Tack Strips... Question. - Flooring - DIY Chatroom Home Improvement Forum
Old 06-30-2012, 11:23 AM   #1
Removing carpet tack strips... question.
Ripping out all of our old carpet to replace it with laminate. While removing the tack strips, every time I pop one of the nails out it takes just a bit of concrete with it. No amount of finesse seems to make them come out smoothly.
Will all of these little areas be a problem if left as-is, or should I address them?
Thank you!
Tyler
Romanova is offline   Reply With Quote
Old 06-30-2012, 11:45 AM   #2
Rewards Points: 13,228
Laminite could care less about a few pot holes.
Make sure you read all the directions about going over a slab with laminite.
Some require a vaper barrer and glued seams.
Laminite would not be my first choise when going over a slab.
rusty baker (06-30-2012)
Old 07-11-2012, 08:17 AM   #3
Between laminate and engineered, what would be your first choice, and why? I'll be starting this project prior to changing my interior doors.
OKDrew63 is offline   Reply With Quote
removing carpet adhesive before tiling ratherbefishing Flooring 1 01-11-2012 04:43 PM
Refinishing wood steps that were covered by carpet, removing discoloration. ransmit Remodeling 5 05-05-2011 08:28 AM
Carpet in the basement Packer Backer Flooring 16 11-04-2008 12:19 AM
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 08:48 PM
removing carpet kyleGR Flooring 6 09-15-2005 11:49 AM
