Removing Carpet Adhesive - Is It Safe? If So, Easiest Way? - Flooring - DIY Chatroom Home Improvement Forum
Old 08-10-2012, 07:45 PM   #1
Rewards Points: 24
Removing carpet adhesive - is it safe? If so, easiest way?
Hi there,
I'm looking to remove some old carpet in our basement - there's a carpet layer on top, a cushion layer, and then the original carpet. That original carpet appears to have been secured to the concrete floor with an adhesive. See the attached pictures.
The adhesive has a sandy, dusty texture that scrapes away with a blade. I get nervous though, since I'm a DIY-newbie and am not sure if it's possibly an asbestos adhesive.
So my first question - from the looks of it, is it safe to remove myself?
If it is, what's the easiest way to do so? A scraper/sander? A chemical?
Thanks in advance for your help.
H
Removing carpet adhesive - is it safe? If so, easiest way?-flooring-004-small-.jpg   Removing carpet adhesive - is it safe? If so, easiest way?-flooring-005-small-.jpg
handeman is offline   Reply With Quote
Old 08-10-2012, 09:37 PM   #2
Rewards Points: 14,306
http://www.qep.com/images/large/62909.jpg
Not a fun job but this is how it's done.
Lowes and Home Depot have them in the flooring dept.
What do you plan on installing once it's gone?
handeman (08-10-2012)
Old 08-10-2012, 09:41 PM   #3
Too Short? Cut it Again!
I doubt you have to worry about asbestos.
Check with a janitorial supply. They usually have adhesive solvents that will at least loosen the stuff. They get a sharp scraper and have at it. If that doesn't work you will have to sand/grind it off.
As Joe says, not a fun job ahead of you.
The Following User Says Thank You to user1007 For This Useful Post:
Old 08-10-2012, 09:53 PM   #4
Rewards Points: 24
Thanks for the replies! I'm going to pick up one of those scrapers tomorrow.
The plan is to lay down some area rugs on the concrete for now. We want to finish the basement down the road, so best to get this out of the way now.
Old 08-10-2012, 10:04 PM   #5
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 182
Should not contain asbestos. I would not use a solvent for removal. It can keep whatever you install later from adhering.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Tags
adhesive , carpet , concrete , floor , removal
Removing old adhesive for new self-sticks? Baldrick63 Flooring 6 07-15-2012 01:01 PM
Removing dark black spot on light beige carpet X( ninfragile19 Flooring 0 05-03-2012 10:46 AM
Removing Carpet Adhesive glyndwr Flooring 0 10-20-2011 10:37 PM
Partially removing carpet? Kiwi. Flooring 0 02-23-2010 01:17 PM
removing carpet kyleGR Flooring 6 09-15-2005 10:49 AM
