Old 01-11-2012, 03:32 PM   #1
In a little over my head
removing carpet adhesive before tiling
A friend (not on DIYCR, yet), has pulled up the carpet from his concrete basement floor. He's planning on recovering with 18x18 ceramic tile. How meticulous does he need to be removing old adhesive? He says it looks like mastic, but isn't really sure what the adhesive is. Will thinset bind to remnants of carpet adhesive?
Thanks!
ratherbefishing is offline   Reply With Quote
Old 01-11-2012, 04:43 PM   #2
I can fix that!
The adhesive should be removed. Rental shops will have a disk with cutting heads that mounts to an orbital floor buffer/polisher. That is the best way to get it off.
kuhlman is offline   Reply With Quote
Removing carpeting adhesive from wood stairs? P550 Flooring 3 10-02-2009 08:33 AM
Removing old carpet, left over glue...best way to remove it? RyanD General Discussion 5 06-24-2009 05:37 PM
Removing Vinyl Tile Adhesive from Linoleum The Raven Flooring 3 07-22-2008 09:38 PM
What adhesive to use for tiling wall? sz8 Flooring 4 03-21-2008 06:55 AM
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 08:48 PM
