Old 03-27-2012, 09:40 AM   #1
Removing Adhesive and Paint from Concrete
Does anyone have any recommendations on removing stubborn outdoor carpet adhesive and paint from concrete?
I have a large terrace that I am looking to set tile on so I am trying to get it down to bare concrete. The concrete has some industrial strength adhesive bonded to the concrete from the outdoor carpet I took up along with at least 2 layers of paint, most likely oil based. I’ve tried scrapping, chemicals, 3500 psi pressure washing and a handheld grinder with some sort of scrapping/grinding wheel that only heated up the adhesive and gummed up the wheel pretty quick.
The two suggestions which I am headed towards are an industrial grade floor buffer with most course wheel I can get or a walk behind concrete grinder/scarifier. Both options are $200 plus rental. The buffer I am afraid will gum up like the hand grinder I tried. The scarifier sounds excessive.
Any other suggestions? I have learned that chemicals are a no-no for thin-set. Also, if the adhesive is so well bonded to the concrete and it was troweled on in a circular pattern, would this accept and hold thin-set?
Thanks,
John
onthejob is offline   Reply With Quote
Old 03-28-2012, 09:33 AM   #2
Having just gotten carpet glue / thinset off concrete:
-hammer drill with a tile chisel- use the hammer only function. The carpet glue actually came up best with this but it wasn't tacky. Not sure if indoor vs outdoor glue is a big diff
Polapea is offline   Reply With Quote
Old 03-28-2012, 11:06 AM   #3
http://www.soybiobased.org/find-prod...astic-remover/
Old 03-28-2012, 04:01 PM   #4
Floor scraper may get the adhesive off also.
Old 03-29-2012, 11:11 AM   #5
I’m trying to avoid using chemicals because I have to use thin-set to set tiles and I don’t want to take the chance the chemicals won’t let the thin-set bond to the concrete. I’ve tried a floor scrapper and got no where. I like the hammer drill with the chisel tip. Might have to give that a try. The rental company said the concrete grinder/scarifier will gum up and be useless. No one in my area rents shotblasters which sounds like my best option.
Is it necessary to get rid of paint on concrete before laying ceramic tiles? yummy mummy Flooring 41 03-17-2013 10:46 AM
Concrete prep for outdoor tile onthejob Concrete, Stone & Masonry 8 03-29-2012 01:34 PM
Epoxy paint over black mastic over concrete in basement kidnitro6 Flooring 0 03-21-2012 03:50 PM
Removing Adhesive from concrete jillofalltrades Flooring 5 07-22-2011 07:13 PM
Paint will not stick in Bathroom! SGTHetland Painting 9 08-18-2008 12:04 AM
