Removing Adhesive From Concrete - Flooring - DIY Chatroom Home Improvement Forum
Old 07-21-2011, 06:02 PM   #1
Removing Adhesive from concrete
I am trying to remove outdoor carpet and its adhesive from a concrete patio. I have tried scraping, adhesive remover, boiling water, pressure washing, and crying tears. Nothing is working. Until I remove this hideous stuff, I can't do anything with this outdoor space. Does anyone know how or who can remove this stuff or how to cover it, decking board?, patio pavers? I am trying to do this on a very small budget which is why I would like to remove the adhesive and just paint the concrete by myself. Any suggestions would be greatly appreciated.
jillofalltrades is offline   Reply With Quote
Old 07-21-2011, 06:46 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 52
The only way I have ever removed it is scraping.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 07-21-2011, 06:55 PM   #3
you'll need a 4" blade scraper from home depot etc. its the kind that fits actual 4" blades in the end of it and with those you can scrape the adhesive much easier. Don't forget at least a cheap pair of knee pads & gloves (saves those soft hands
HarryJ is offline   Reply With Quote
Old 07-21-2011, 10:13 PM   #4
Rewards Points: 1,016
A high capacity pressure washer with appropiate tip would take it off I would think, not a homeowner unit - a large rental unit. But maybe not.
I once rented a power scraper one time to remove tile adhesive from interior concrete. It did not eliminate the manual work - but did 80% of the job.
____________
Vince
Old 07-22-2011, 06:37 PM   #5
Rewards Points: 1,570
4" grinder with an abrasive disk or pad works; depends how big an area though. Not for an entire floor but areas where it is thick and you've tried the scrape method.
bob22 is offline   Reply With Quote
Old 07-22-2011, 07:13 PM   #6
Rewards Points: 52
It is tough to remove. I have always pointed this out to customers before installing turf. I didn't want them to be surprised down the road, if they decided the wanted to change the area later. .
concrete adhesive or mortar ? petedoro Building & Construction 0 05-06-2011 04:44 PM
What type of adhesive should I use to glue down accoustical cork to a concrete floo Fixitgeorge Flooring 2 03-20-2009 08:54 AM
Removing post set in concrete Bill Reader Landscaping & Lawn Care 6 10-20-2008 02:57 PM
Concrete Adhesive la15ota Landscaping & Lawn Care 2 09-28-2008 09:49 AM
Adhesive removal from concrete sod Flooring 3 04-02-2007 09:41 PM
