Removing 2k Feet Of 4 Year Old Ceramic Tile - Flooring - DIY Chatroom Home Improvement Forum
Old 05-08-2012, 10:00 PM   #1
removing 2k feet of 4 year old ceramic tile
Hey guys, been browsing here but this is my first post. My "lovely" wife and I just purchased a beautiful home, complete with the Florida standard of ceramic tile throughout the living spaces (built and tiled in 2006). My wife, however, wants wood floors, and absolutely hates the white-ish tile. So, my question is pretty broad, but what is the best way to remove the 12x12 ceramic tile from the concrete subfloor, in order for me to glue down solid strand bamboo hardwood? I was thinking of renting one of the heavy self-propelled floor strippers, but the Depot and a local rental spot said they don't work well on ceramic. Thoughts? Experiences to share? Thanks everyone!
floridafireman is offline   Reply With Quote
Old 05-08-2012, 10:15 PM   #2
Rewards Points: 14,300
One of these with a wide tile chisle (it has a raised area in the middle of it to lift and split the tiles, ear protection lots of 5 gal. buckets, flat shovel, floor scrapper, wide broom , shop vacuum, knee pads.
Concider using engineered wood flooring instead, It can be installed as a floating floor, looks like real wood because it is.
And may be able to go over the tile you have now.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
floridafireman (05-08-2012), Ravenworks (05-10-2012)
Old 05-08-2012, 10:41 PM   #3
You said "one of these" but didn't indicate or show what you meant by it... I considered engineered floors over tile, but i don't want to have to raise everything. The engineered floors were not as durable as the strand woven in my tests, either. I have honestly never heard any real negatives about the strand woven bamboo, other than it just isn't the look some people prefer. So, would you not recommend trying to rent the floor stripper?
Old 05-08-2012, 10:49 PM   #4
Opps http://www.amazon.com/Bosch-11255VSR.../dp/B000BB79Q6
I personaly never seen a floor scrapper that could remove tile.
You could still get the same material, same look in engineered flooring.
Old 05-09-2012, 01:25 PM   #5
Retired Cabinetmaker
woody4249's Avatar
Rewards Points: 156
A light weight jack hammer with a 3" bolster chisel does well.
Sometimes you won't know until you start to do it as to how hard it will be to remove. A rule of thumb in Florida is $1 a sq ft by the pro's to remove.
You can get bamboo 2mm veneer engineered flooring with a high Janka hardness rating.....real good value also
"I'm not as green as I am cabbage looking"
woody4249 is offline   Reply With Quote
Old 05-10-2012, 04:22 PM   #6
I agree with the tile chisel. Another option might be to float an engineered wood floor over the tile. This would save a whole lot of work removing these tiles. Tile will also generally make for a nice solid subfloor for this.
RhodesHardwood is offline   Reply With Quote
Old 05-10-2012, 04:39 PM   #7
Ravenworks's Avatar
It is a lot easier than you think if you plan the job out well,I don't think you realize what a royal PIA this job you're planning on is going to be,not counting the what if's you will find along the way.
They make chipping hammers (small jack hammer) in PINK ! (hint)
Ravenworks is offline   Reply With Quote
Old 05-10-2012, 08:08 PM   #8
woodman58's Avatar
This is the easiest way I know to remove ceramic from concrete. Go to one of the big box stores and purchase a portable compressor with atleast 5CFM @ 90 PSI. (Dewalt makes one $349) The compressor will run constantly so, make sure and let the compressor catch up. clean up the tile you have chiseled up. As mentioned before us alot of 5 gal. buckets. Anthing bigger will be to heavy. Also, in tool department is an air chisel set. ($15 - $30) Get an air hose and a good metal file. Start by taking a hammer and break up one tile. This will give you a place to start. Use the one inch wide chisel from the set and put it next to the next tile and pull the trigger. The tile will pop up in peices (sometimes whole) so, wear googles and ear protection. I take tile up this way all the time. For the most part it comes up good. It will even take up the mortar. Make sure and use the file often on the chisel and keep oil in the air gun.
I LOVE THE SMELL OF SAWDUST IN THE MORNING!
woodman58 is offline   Reply With Quote
Old 05-10-2012, 08:51 PM   #9
Just a DIY guy
this does seem like a monumental job that would be easier to do if you laid the floor on top of the tile. There are strand woven that can be floated
http://www.bamboorevolution.com/SW-FF.pdf
http://www.builddirect.com/Bamboo-Fl..._10071122.aspx
Good luck.
M3 Pete is offline   Reply With Quote
Old 05-11-2012, 05:24 PM   #10
i would use this, with a 2 inch blade instead of the 24 or whatever is picture.
but then again i know someone that owns one of these and would let me borrow it
you can look into it for rental though, as it's going to be much much much less work than chipping hammers.
sevenlol is offline   Reply With Quote
Old 05-11-2012, 08:02 PM   #11
Ravenworks's Avatar
Regardless of how you remove the tile,then comes the real fun,grinding the thinset that is left behind,grinding it not fun and very dusty.
DuraCeramic over Ceramic tile? SueC Flooring 10 03-17-2011 11:07 PM
ceramic tile walls with mastic Boris100 Building & Construction 2 02-14-2011 09:39 AM
Ceramic tile over existing (full mud) ceramic? rjniles Flooring 7 12-24-2008 06:12 PM
Removing tile from plywood underlayment Martinglmt Flooring 3 12-13-2008 07:06 PM
Removing Ceramic Tile csnolan General DIY Discussions 1 10-26-2007 10:37 PM
