Removing 2 Layers Of Sheet Vinyl - Flooring - DIY Chatroom Home Improvement Forum
Old 12-12-2009, 01:51 PM   #1
Rewards Points: 87
Removing 2 layers of sheet vinyl
Help! I'm slowly removing 3 layers of vinyl floor down to the plywood. I can remove the vinyl squares and then use a prybar to loosen the other two layers of sheet vinyl. The problem is this: how to cut the 2 remaining layers of sheet vinyl so I remove it in a manageable size. I've tried jigsaw and dremel multimaster. But it seems to inadequate for the job.
Any suggestions?
Thanks all.
momof2labs is offline   Reply With Quote
Old 12-12-2009, 05:03 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 14
You must have dull blades. I have taken up hundreds of yards of vinyl. Just cut it up with a utility knife.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 12-12-2009, 10:17 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
...or a circular saw set to the required depth.
Been doing this for more than thirty years and never once had a floor covering of this type that couldn't be removed with a little effort.
XXX
Old 12-12-2009, 11:30 PM   #4
Tileguy
JazMan's Avatar
Rewards Points: 244
You need to identify what that plywood is. Chances are the vinyl was installed over a 1/4" ply or something, and that has to be removed too down to the subfloor. Get to an edge or drill a hole to see and measure what is there. Then report back here.
Jaz
Old 12-12-2009, 11:46 PM   #5
Rewards Points: 14
Depends on what he or she is installing whether the underlayment has to come up or not, They didn't say. You could concievably install laminate or Konecto over the old underlayment.
Old 12-13-2009, 01:16 AM   #6
Get out of the box!
Rewards Points: 260
Like Rusty said get some good sharp blades, and cut it in to strips, the smaller the strip the easy to peel.
We have cut into 3-5 inches strip before just to get it loose.
Schluters Kerdi Shower System, Ditra. Loxcreens ProVa Mat Shower Systems
Konecto Luxury Vinyl Plank,Armstrong and Hardwood flooring.
https://IndianaFloorsLLC.com/default.aspx
26yrsinflooring is offline   Reply With Quote
Tags
old kitchen floor , old vinyl floor
seal seams on self sick tiles NoExperience Flooring 3 08-12-2008 08:25 PM
vinyl sheet or tile (or allure) over old vinyl? thomase Flooring 8 06-30-2008 06:15 PM
Sheet Vinyl Flooring Removal yoods Flooring 2 11-22-2007 01:04 PM
