Removing 1 Ceramic Tile Without Damage? - Flooring - DIY Chatroom Home Improvement Forum
Old 03-24-2013, 03:02 PM   #1
Rewards Points: 89
removing 1 ceramic tile without damage?
Recently helped my daughter buy her first home (townhouse that needs work). The entryway, the hallway, and all of the kitchen is done in ceramic tile (big area). Problem: there is one tile missing in the entryway area. This townwhouse is 30+ yrs old--so finding a match is out. However, they did tile under the kitchen range & refigerator. --So, I was thinking of salvaging a tile (or two) from one of these hidden areas. Any suggestions as to how I can get a tile from these areas without breaking it? I suppose I will need to break a few to get one good one---but is there an easy way to get one good one? Any help will be appreciated. ---JAES.
jaes is offline   Reply With Quote
Old 03-24-2013, 03:17 PM   #2
Rewards Points: 13,274
There's about a 1% chance of getting one out without breaking it.
Got to remove the grout first.
Old 03-24-2013, 07:50 PM   #3
Rewards Points: 89
I was thinking of this method----
Ok, I don't know much about tile, so that's why I asked the question in the first place. Here's what I was thinking: Remove grout around several tiles, break-up 3 tiles around the target tile, and use a hacksaw ---maybe a sawsall to saw under the target tile. ---That's what I was thinking, BUT there may be a better way?? Any thoughts? __Again, thanks for any helpful suggestions. ---JAES.
Old 03-24-2013, 10:08 PM   #4
There really is no tool or suggested way to remove just one tile and reuse it.
Most are set in a morter mix that's super strong so the tiles will not move.
Best you can hope for is someone did a poor job installing them, or they layed it over something they never should have.
Removing durcock with ceramic tile attached? pgriswold Drywall & Plaster 7 03-09-2013 08:28 PM
Could use some help on ceramic vs duraceramic tile helpmike Flooring 17 03-29-2011 11:42 PM
Replacing Ceramic tile floor handy andy Flooring 4 03-28-2011 01:07 AM
Concrete floor prep for ceramic tile tpanc13 Flooring 39 06-22-2010 09:50 PM
Removing Ceramic Tile Blaze25 Flooring 2 11-16-2006 09:52 PM
