Old 03-04-2008, 02:59 PM   #1
Default Removed basement stairs - put in floor for washer and dryer
Hello,
Background:
Moving into a house. The old owner took out the interior stairs to the basement as there is a door to the basement that leads to the outside. They did this to put the washer and dryer in its place - so essentially making what used to be a stairwell into a closet.
He patched up the whole with I guess plywood. some 2x4s and a metal beam to hold up one of the corners in the basement. He then put stackable washer and dryers on the new floor he put in himself.
Well the inspector went through and said that floor needed to be replaced or fixed to make sure it will not have problems down the road. I could see what he was saying.
What I would like to do:
Well while we are getting it fixed up I thought instead to just remove what he put there and instead create a floor that is 'recessed'.
Here is the point, I would like to put a new washer and dryer in the spot of the old ones. They will be those washer and dryers with the front access doors. So I would like to make the floor so that the washer and dryer and sitting lower than the floor on the first floor.
Two reasons: 1 because my g/f is short and getting the knobs on the top of the stacked dryer my prove a bit tricky
and 2: If the washer ever flood - the recessed floor would give a better chance from the 1st floor from water damage.
Ok - so if that made sense to anybody - is this something I can do myself or do you think I should hire someone? You not knowing my abilities I can say I envision what would need to be put together, I am decent with my hands. All I need is a bit of help to plan out the details of the design.
I am also concerned about how the washer and dryer would bang around a bit and the floor would never have a consistant weight while the washer and dry is in motion. I guess the washer and dryer we are looking at can have cement or something put in it to weigh it down and prevent shaking but i understand that this is not 100% fool proof. So - with that said, I do not know if my decent but not professional skills can create something to withstand the pressure of a washer and dryer shaking.
Thoughts?
capslock is offline   Reply With Quote
Old 03-04-2008, 06:44 PM   #2
J Calvin Construction
jcalvin's Avatar
Best idea is to build the floor back the same level as the remaining house. Buy you g/f a stool or trade her in on a taller version . I don't know if you know of a washer/ dryer combo that never goes out but its going to be a b^&*$ to pick that hunk of lead up out of that hole your going to frame. If it was me, I would rebuild the steps and put the w/d back down in the basement were you can roll those puppies right of the truck and set up.
Sorry about the g/f joke, go buy here a front loading Bosch 500 series set. She will love them.
Cal
You hired WHO?
jcalvin is offline   Reply With Quote
More On This Topic
We are standing in a room that used to be a carport when the house was originally built and somewhere along the line one of the owners has turned this in to a living quarters, whether it be a bedroom or a family room or whatever and we are in the process... Read More »
Okay, now we need to prepare the material. Most people would recommend that you should wash and dry your material before you start, I say that's debatable. Some materials you have to, some depending on what you're making, not as necessary. This dress I... Read More »
In painting my walls, I’ve come across an issue that I need to deal with, and that is this 220 volt outlet. We used to have the washing machine and the dryer upstairs and we’ve moved it to the basement. This can’t come out, and we... Read More »
Hi! My name is Leslie Moselle and I am from Tampa, Florida and on behalf of Expert Village, this is how to do laundry. Delicate clothes are probably the most important thing to be careful with when drying. There are two options for drying your delicate... Read More »
Hi this is Jon on behalf of Expert Village in this video clip we'll be turning off the water. Now some tubs have an access panel or you can actually reach into the wall and they'll be a shut off valve located in the wall that will just shut off the water... Read More »
Dryer vent. kcrossley2 Plumbing 10 02-20-2008 02:02 AM
Location of 220 and 110 outlets for dryer and washer JAJJ Electrical 2 08-07-2006 11:16 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
