Remove Tile Laid Over Hardwood - Flooring - DIY Chatroom Home Improvement Forum
Old 02-03-2013, 12:53 PM   #1
Rewards Points: 205
I have recently acquired a 1960s home. While doing some work in one of the rooms, I noticed that one of the previous owners had laid the tile over hardwood. They did not do it properly with any backer board.
There are numerous broken tiles and some spots where the tile is obviously coming up.
On my project list is to replace the flooring. So what to do?
I don't think the HW is salvageable and truthfully, it sounds like a HUGE project. We must live in the home while the work is underway.
Looking for a miracle solution!!
CosmicMiami is offline   Reply With Quote
Old 02-03-2013, 02:32 PM   #2
DIY staff
Rewards Points: 7,174
That tile will pop right off---get a hand held hammer about 3 pounds and start knocking them off---
when demoing the hardwood---be careful if you use a circular saw---in those days the hardwood was frequently laid over 1x4 sleepers with electrical conduit between the subfloor and the hardwood.
Figure that out before you get carried away-----
Old 02-03-2013, 03:43 PM   #3
Rewards Points: 13,694
Once you get a few up sometimes I've been able to pop them off with just a flat shovel they were so loose.
If you can figure out where the joist are you can make cuts between the joist to make it easyer to remove the flooring.
I use one of these to pop them off.
http://www.thegutster.com/
Northern Tool sold then at one time.
Any way to get under the floor to see if it was just laid over the joist with no subflooring?
Old 02-15-2013, 07:59 AM   #4
Rewards Points: 205
I'm not so much worried about getting the old tile up. I'm sure it will come up without too much problem. What to do after that?
I know, it depends on the integrity of the hardwood. Just wondering if anybody has seen this and if there is a chance the hardwood will be good.
Thanks.
Old 02-15-2013, 08:08 AM   #5
Not very likly.
Old 02-15-2013, 08:35 AM   #6
Rewards Points: 205
Originally Posted by joecaption View Post
Not very likly.
I figured that.
With that in mind, I have a few options after removing the tile.
  1. Install laminate over the existing wood floor
  2. Remove the hardwood and start from the subfloor
I don't see too many other options. Keep in mind, I would like to minimize daily disruptions. There doesn't seem to be an option of doing this project in stages.
If I decide to take the easier route (laminate), Would that require me to remove ALL the existing mortar or just the high spots? I think I know the answer. Which would lead me back to option 2!
Old 02-15-2013, 08:37 AM   #7
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 112
The floor needs to be smooth and flat for laminate. (Remember, level and flat are not the same thing.)
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
rusty baker is online now   Reply With Quote
Old 02-15-2013, 08:45 AM   #8
Rewards Points: 205
Understood. Thanks.
Remove old hardwood glue b4 laying tile? MariJane03 Flooring 6 11-28-2012 10:52 PM
Floating hardwood transitions to carpet and tile adefields Flooring 2 11-21-2012 11:39 AM
Hardwood over tile?? drjay9051 Flooring 5 10-13-2012 08:49 AM
Removing Tile Over Hardwood: Need Help With Kitchen/Bath Creelove Flooring 3 02-01-2011 06:03 AM
Hardwood transition to ceramic tile willyberger Flooring 5 08-09-2009 11:38 AM
