Remove Screwed And Glued Subfloor - Flooring - DIY Chatroom Home Improvement Forum
Old 03-15-2012, 11:54 AM   #1
Remove Screwed and Glued Subfloor
I am replacing all the carpeting in my two story home and have completed the tear out of the old carpet and pad. While I have it out I though it would be a good time to install recessed lighting on the first floor by lifting the subfloor on the second floor so I could access the first floor ceiling from above. When I started to remove the necessary pieces of subfloor I discovered they are screwed and glued. Is there a trick to removing the screwed and glued subfloor? Should I just abandon my dream of wiring from above and just cut a slit in the ceiling from below so I can run the wires perpendicular to the joists? Any help would be much appreciated. Thanks, Kevin
anon8933 is offline   Reply With Quote
Old 03-15-2012, 01:14 PM   #2
Don't WANNA do it myself
mnp13's Avatar
Rewards Points: 502
take the screws out and try heating the glue to see if it will soften and release.
Or you could take the screws out and cut the plywood into strips and break it out with a crowbar. Then cut a replacement patch from another sheet when you're done.
Michelle
Fixing the re-muddling one room at a time...
mnp13 is offline   Reply With Quote
Tags
recessed lights , subfloor
fix squeaking subfloor stev9erphi Building & Construction 18 01-05-2012 07:32 PM
plywood over existing subfloor - not glued? rtoni Flooring 3 10-14-2010 11:37 AM
Subfloor and Underlayment Questions JulieZ Tiling, ceramics, marble 14 06-23-2009 08:04 AM
Kitchen subfloor questions tishimself Tiling, ceramics, marble 7 12-09-2008 09:16 AM
Information needed on replacing kitchen subfloor lyren1970 Flooring 2 07-17-2008 01:03 AM
