Old 12-25-2012, 09:37 PM   #1
remove old paint from concrete basement floor
I have a home built in the 50s and the concrete floor is covered in an undesirable paint color. I would like to remove it mechanically and I'm wondering what some good methods are? I want to get it back to bare concrete. Thanks!
figureitout is offline   Reply With Quote
Old 12-26-2012, 02:42 PM   #2
I am interested in this as well. While mine is an ok color, I would like to epoxy mine, and prefer not tp put it over the paint
jimmyfloyd is offline   Reply With Quote
Old 12-27-2012, 12:56 PM   #3
if you have a drain, i would try a pressure washer.
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour
i didn't make this world. i just live in it.
be careful of whom you make fun of. one day, that could be you...
Fix'n it is offline   Reply With Quote
Old 12-30-2012, 03:18 AM   #4
Not sure how much paint you are trying to get up, but I have had good luck using simple green to strip paint from old metal door knobs, and just recently used "goof off" to get caulk, paint and glue off a tile floor.
The simple green I soaked the door knobs, so depending on the area that needs paint removed you could make make a little "pool" and let it soak.
troyce1 is offline   Reply With Quote
Tags
concrete floor, paint removal
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 08:46 PM
Should I remove tile floor after minor flood? dan1980 Flooring 5 05-24-2012 04:48 PM
Help picking a floor for basement painted concrete erinhall Flooring 1 05-07-2012 05:33 PM
Concrete Basement Floor Insulating options McSweny1103 Insulation 7 03-08-2011 06:24 PM
Flashing NoExperience Painting 13 09-04-2008 06:56 AM
