-   -   remove old paint from concrete basement floor (http://www.diychatroom.com/f5/remove-old-paint-concrete-basement-floor-167368/)
figureitout 12-25-2012 09:37 PM
I have a home built in the 50s and the concrete floor is covered in an undesirable paint color. I would like to remove it mechanically and I'm wondering what some good methods are? I want to get it back to bare concrete. Thanks!
jimmyfloyd 12-26-2012 02:42 PM
I am interested in this as well. While mine is an ok color, I would like to epoxy mine, and prefer not tp put it over the paint
Fix'n it 12-27-2012 12:56 PM
if you have a drain, i would try a pressure washer.
troyce1 12-30-2012 03:18 AM
Not sure how much paint you are trying to get up, but I have had good luck using simple green to strip paint from old metal door knobs, and just recently used "goof off" to get caulk, paint and glue off a tile floor.
The simple green I soaked the door knobs, so depending on the area that needs paint removed you could make make a little "pool" and let it soak.
