Remove Mastic From Concrete Slab - Flooring - DIY Chatroom Home Improvement Forum
Old 11-14-2011, 04:05 PM   #1
Remove mastic from concrete slab
I'm bonding solid hardwood flooring over a concrete slab using Bostik Dura-Grip. A Bostik tech rep told me that I need to remove all of the black mastic where vinyl tiles were installed for their product to work properly. I've scraped up as much as I can but need go deeper to get the rest. I'm afraid to use a chemical remover because concrete is porous and insufficient cleaning afterward could prevent proper adherence.
What is the best way to remove black mastic (and tan mastic in one room) without chemicals?
CountDowne is offline   Reply With Quote
Old 11-14-2011, 04:48 PM   #2
DIY staff
Rewards Points: 7,174
Ask them of using a self leveling compound over the cutback is an acceptable surface----
Jiffset mixed with Linewebers latex is acceptable over cutback for tile installation---but I would wonder if the bond is strong enough for solid hardwood---
Also call Jiffset--
Old 11-14-2011, 04:52 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 290
Wait.....since when is that an acceptable installation? Maybe things have changed since I sold and installed hardwood though.
What brand and specific hardwood are you using and who told you it's a recommended practice?
Jaz
JazMan is online now   Reply With Quote
The Following User Says Thank You to JazMan For This Useful Post:
oh'mike (11-14-2011)
Lay plastic between ground and concrete slab? Flt_Simulation Flooring 8 04-22-2012 06:56 AM
Cement backer board over kitchen concrete slab gtimk4 Flooring 2 02-19-2012 03:46 PM
engineered hardwood over concrete slab BSCHO Flooring 4 02-01-2011 11:00 PM
Removing concrete slab on 3rd floor bathroom NowItsShowtime Flooring 2 03-26-2009 03:17 PM
PVC underneath the floor (concrete slab) massimo Building & Construction 6 11-19-2008 11:37 AM
