Remove Or Leave Vinyl - Flooring - DIY Chatroom Home Improvement Forum
Old 03-26-2008, 08:04 PM   #1
Question
Remove or leave vinyl
I am getting ready to put new laminate down and I have a few questions.
1. I currently have sheet vinyl over a concrete slab. The vinyl is in decent shape (a few small cuts/tears and a couple of spots where it is coming up). Is it recommended to simply glue the spots back down and then lay the laminate over the top?
2. For the vapor barrier, should it simply go up to the wall or should it extend up the wall a bit? And is it taped to the wall?
3. This is a kitchen and the laminate needs to have a sealant in some places according to the manufacturer. Would it hurt to put sealant around the entire perimeter (I know it would probably be overkill)?
Thank you for any help you can offer! This is my first flooring project!
tlewis is offline   Reply With Quote
Old 03-27-2008, 12:32 PM   #2
Tile and Paint contractor
You should completely remove the existing vinyl before installing a new floor covering.
Although the vinyl may muffle that funny "clicking" sound that laminate makes when you walk over it.
Matt | tile contractor
Charlotte, NC
MattCoops is offline   Reply With Quote
Old 03-27-2008, 12:56 PM   #3
Thanks for the reply! I was leaning towards removing the vinyl, but I know other people that have put the laminate over the vinyl without any problems.
Sheet Vinyl Flooring Removal yoods Flooring 2 11-22-2007 12:04 PM
remove damage vinyl tiles harold938 Carpentry 2 11-16-2006 12:14 AM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
