Old 08-12-2012, 08:48 AM   #1
Remove just tile & Reuse base??
Hi folks, I have a 10 year old house and want to re-do the tile in the bathroom floor. The current tile is the little polygon shaped type attached to mesh in the back. Using a hammer drill and chisel I was able to test and knock off just a few of the tiles I didn't go all the way into the base.
MY QUESTION IS: do I have to remove all the way down to the plywood too or can I knock the tiles off and then just "re-thinset" and "re-tile" over the existing backerboard/thinset base??
I have read I can tile over the tile which does seem pretty solid but I believe the mesh backing makes it easy to pop just the tile off. Removing everything looks like a PITA!! So my other option would be tile over tile!
PLEASE HELP...!!
hollywood33 is offline   Reply With Quote
Old 08-12-2012, 10:21 AM   #2
Super Moderator
Tell us what the old tile is set over---reusing the old backer is usually a nightmare---if set with cement based thinset the old cement board will be ruined--if set with a mastic--the old cement board will also be ruined.
If set over plywood---well--you need a tile backer if you want the safest job---
Pictures help--or a better description of what's there will do.
Old 08-12-2012, 11:41 AM   #3
Ok cool...first level is plywood base, then some type of mortar to which cement board was attached along with screws, then thinset, then the tiles which are on a mesh backing.
Like i mentioned i can slide the chisel right under tiles and pop them off one by one with some force.
I want to know if I can leave the current cement board down and put new tiles on top after removing old poly-shaped tiles.
Old 08-12-2012, 01:15 PM   #4
Super Moderator
Yes you could reuse the backer board.
I think pulling it out and starting fresh will be easier and give you a smooth surface--leading to a better job---
But in one word--YES---
hollywood33 (08-12-2012)
Old 08-12-2012, 02:36 PM   #5
Thanks Mike, just busting up to the subfloor is causing so much dust. That mesh backing makes popping those tiles off kinda easy.
Is there any thin-set/mortar you would recommend to use over the old backer board since it still it will still have old thin-set remaining on top??
Old 08-12-2012, 03:23 PM   #6
Super Moderator
You wwill want to use a powdered -modified thinset---"Mud" What Is It? - Kitchen & Bath Remodeling - DIY Chatroom - DIY Home Improvement Forum
Also--if the surface is not flat, a Self leveling compound could be used to bury the ridges of the old thinset.
How to Remove Tile to replace in-floor sensor! Help! ryan5068 Tiling, ceramics, marble 6 03-26-2012 08:40 AM
Vinyl sheet tile install - remove or level ceramic? Craigkapo Tiling, ceramics, marble 3 01-21-2012 02:13 AM
How to remove outlet from tiled wall, then patch drywall and retile? Jakobud Kitchen & Bath Remodeling 18 10-15-2011 05:05 PM
How to remove old tile floor to prepare for new one Toocool100 Tiling, ceramics, marble 9 07-31-2011 06:19 PM
How do I remove this ceramic tile? tripower Flooring 5 07-23-2007 10:45 PM
