Remove Haze From Wood Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 03-26-2011, 06:38 PM   #1
jkb
Remove haze from wood floor
How do I remove the haze that Mop & Glo wood floor cleaner left on my mahogany wood floor?
jkb is offline   Reply With Quote
Old 03-27-2011, 06:45 AM   #2
woodman58's Avatar
A 50% water, 50% viniger solution should take it off. Use a rag on your hands and knees. I had a customer do the same thing to thier Brazilian Cherry. It looked fine afte she was done. From now on only use a wood floor cleaner or water to clean. Anything else will leave a residue and build up causing your floor to dull again.
woodman58 is offline   Reply With Quote
Old 03-27-2011, 07:47 AM   #3
Aged Sleeper
Bken's Avatar
I agree. Use the solution, but after it is clean you must remove the residue from solution and clean it again with a wood cleaner like bona hardwood floor cleaner & keep using that as a weekly cleaner.
Also use the refresher every 6 months and that will keep your floors looking good for a long time.
(Side note: this applys as long as this is a urethane finished floor)
Bken is offline   Reply With Quote
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 01:37 PM
warming cold wood floor dave1123 Flooring 5 07-06-2010 08:41 AM
Carpet in the basement Packer Backer Flooring 16 11-03-2008 11:19 PM
Removing floor tile glue from a wood floor mrmordun Flooring 2 09-03-2008 09:41 PM
