Originally Posted by headcrash0101
I am trying to find out the best way to cut the hardwoods at the door.
A sharp circular saw...with a straight edge to follow. Use double stick tape to hold your straight edge. You may have to score the surface cut line first, cut then finish with a hand saw.
Do they make a marble threshold that will cover the wood floor slightly.
Sorry, the ones I've seen are square edged.
If not what is the best way to cut the wood straigh and with a fine cut.
see above
Also will there be a gap between the wood and the threshold. The threshold will sit on the backer board.
depends on how straight you make the cut.
