-   -   Remove hardwood for tile (http://www.diychatroom.com/f5/remove-hardwood-tile-22547/)
headcrash0101 06-20-2008 02:25 PM
I am tiling a bathroom that currently has hardwood floor. The floor run continuous from the hallway into the bathroom. I want to remove the hardwood in the bathroom and install backer board and tile. At the doorway i want a marble threshold. I am trying to find out the best way to cut the hardwoods at the door. Do they make a marble threshold that will cover the wood floor slightly. If not what is the best way to cut the wood straigh and with a fine cut. Also will there be a gap between the wood and the threshold. The threshold will sit on the backer board.
RippySkippy 06-20-2008 05:03 PM
A sharp circular saw...with a straight edge to follow. Use double stick tape to hold your straight edge. You may have to score the surface cut line first, cut then finish with a hand saw.
Sorry, the ones I've seen are square edged.
see above
depends on how straight you make the cut.
kshankle 06-20-2008 05:32 PM
how about removing tile for hardwood?
RippySkippy 06-23-2008 10:26 AM
And the question is.......?
kshankle 06-23-2008 02:18 PM
do you have to rip out the tile or can you just glue it right on top of it?
RippySkippy 06-23-2008 03:21 PM
hopefully others will chime in...but I would remove it. It kind of depends on the elevations of the surrounding floor. With the tile left in place would the new floor height be too tall? What adhesive would you use to securely fasten the floor to the tile?
Again...if it were mine, it would come out. But maybe that's just me.
